Thread: What to look out for when buying a 1.9 150
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default What to look out for when buying a 1.9 150
    Thinking of buying a 1.9CDTi 150PS. A nice 05 Vec Estate Elite with supposedly 71k miles.
    How do I know the manifold has been changed? Anything else I should be worried about? How do I check the swirl flaps bar?
    http://www.avto.net/_AVTO/ad.asp?ID=3248638&show=1
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    look at service history and ring the dealers- they will fax you a print out on all the work that has been done............mine was never ending loll, hope that helps
    Andy
    Leicester
    I would just make sure it has a decent service history. I would'nt know how to check if the inlet manifold has been changed as I have never had to change one.
    If you know anyone with tech 2, you can operate the swirl flaps by Tech 2 to ensure they operate OK.
    Other than that, go for it, anything more than 60,000 miles then I would suggest changing the water pump and cam belt/tensioners/rollers etc and have a full software check and update, then your all set.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    My mate has OP-COM so I could chech with that
    The car in question is almost certainly from Italy. Slovenian Elegance models had xenon headlamps as standard, like my 3.0CDTi
    It's going to be difficult to check service history, but since they offer warranty the vehicle shouldn't be too bad. My mum's 2.2DTi Auto has 116k miles and she wants to get rid of it. It's just too thirsty nowdays struggles to achieve 37mpg.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    In addition to the previous comments, with regard to the swirl flaps, you can always just pull off the top cover and take a peek to see if there's a load of heavy dirty gunk/oil around the connecting rod area, if its well worn it will be quite badly gunked up with black crap. Unless its been replaced or cleaned up by previous owner of course. At least you can see if everythings connected and working.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    eveythink under the bonnet...good luck
  1. Buying a DTi ??????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 09:21
  2. Buying from LMF
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 16:17
  3. 3.2V6 what to look for when buying???
    By Tavli in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 13:50
  4. Help buying a SRI 120 or 150 with or without SAT NAv
    By uncle in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 20:38
  5. what have i been buying?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2006, 08:15
