Results 1 to 10 of 11
Thread: cruise control
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default cruise control
    hi all
    i have noticed that my cruise control keeps turning off on its own for know reason,
    when i switch it on after a second or two it just switches off,have you got any ideas please.
    i dont use it that often but you know wot its like if you have it then it got to work properly
    king regards
    WGAF#5
    clutch pedal switch spring is probably weak and needs replacing - vx do a kit
    Nov 2009
    south wales,Cwmbran
    i must admit that i have noticed that the clutch pedal is quite sloppy but wouldnt have put the 2together
    how does this affect it then mucker
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The cruise control can be switched off by the indicator stalk button or by either the brake or clutch switches to save time fiddling with stalks standard on the vast majority of cruise control systems.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    I have the same problem, found if you put your foot under the clutch and pull it up, then press the cruise control button, it stays on!
    Regular Member suggs1971's Avatar
    east cleveland
    Yep mine did the same, the spring had snapped on mine so bought the modified spring, took 10 mins to fit and cruise control working
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    modified spring?!?
    Oct 2009
    Teesside
    Quote Originally Posted by leemarksmith View Post
    modified spring?!?
    Its a spring thats been modified
    Been serious I believe its just a stronger more durable spring!
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    cheers...
    anyone have the part number or a picture... just in case mine still aint working properly tomo?
    11 Post(s)
    Clutch spring mod:-
    http://www.vectra-c.com/forum/showthread.php?t=33621
    (found via the search tool on this site)
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
vectra cruise control keeps turning off
vectra c cruise control keeps turning off
