Results 1 to 10 of 13
Thread: R/H indicator cancelling
    Apr 2009
    Norwich, UK
    Default R/H indicator cancelling
    Armed with the knowledge gained from posts in this forum, I took my Veccie in to dealer today to have them look at the R/H indicator cancelling problem. I explained I felt it was dangerous, and that the information I had from this forum was that it is a very common fault, and required either steering position calibration or CIM replacement.
    After going walkabout for an hour, I returned expecting the usual 'we can't find anything wrong, sir'. But pleasently surprised, I was told it needed a new CIM. Downside was they fitted one Friday, so it was out of stock.
    So, waiting for a call when it's in, then they want it back for a couple of hours. Still less than 3 years old, so covered under warranty. (That's why I took it in now.)
    Will keep you posted on the outcome, but anyone else with this fault should get it sorted, especially if the car is still under warranty. Not sure what the cost would be otherwise.
    Worcs/Staffs/Westmids (ish)
    Not sure what they mean by CIM and im not sure how VX do this, but the optical sensor used by many cars for self canceling (basically they pass IR through a rotary disc with cutout holes and count the number of light pulses) can get bunged up with grease from the steering column and cause all sorts of issues.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Good result at least there doing some thing
    Irmscher Insignia CDTI 130
    Apr 2009
    Norwich, UK
    I believe CIM is column interface module, or maybe information module. It is part of the CAN bus system. It's like an ECU for all the column switches, steering wheel controls, etc.
    Steering wheel position is used in power steering control as well. It aids in the system working out the assistance to provide, in relation to the input the driver puts in, along with road speed etc.
    Most are moving toward pure torque sensors now with the electronic PAS systems, thankfully
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    my 04 vectra design was a pain in the a** with the indicators canceling early when turning right,it would cancel while traveling in a straight line while about to make a right turn on a mini roundabout,yet my 04 v6 cdti which had esp i had no problems at all
    May 2008
    Tyneside
    I believe you can adjust the angle the indicators cancel using tech 2.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    There are two types of indicator flashes...touch/tap the indicator lever up or down to 'change lane' and get three flashes right or left, or push it up or down against resistance to get a continued flashing left or right to make a right or left turn which cancels the indicator when the steering wheel 'straightens up'....we found it strange when we forst bought the car, but have gradually got 'use to it'.
    Sometimes the continuous flash gets confused when approaching & making a right turn into a minor road on a bend when you adjust your position to stop the front end of the car being hit by some t**t cutting the corner.....
    Apr 2009
    Norwich, UK
    Well chaps. Had the CIM replaced Monday, and driven for a few days to check if it has cured the problem. Have to say yes. The R/H indicators now do not cancel with the slightest wiggle of the wheel. So, anyone with the problem, definately ask the dealer to sort it.
    On the subject of dealers, Thurlow Nunn in Norfolk seem really good, much better than Hartwells in Norwich who I have experience of too.
    I assume they upgraded the software in the CIM when it was replaced it, as the steering had a different feel to it.
    Thanks to previous posters who suggested it was the CIM, as I used that information to nudge my dealer in the right direction.
    Quote Originally Posted by rogerp View Post
    Quote Originally Posted by solorider View Post
    my 04 vectra design was a pain in the a** with the indicators canceling early when turning right,it would cancel while traveling in a straight line while about to make a right turn on a mini roundabout,...
    Yep, same issue I had way back and had a new CIM fitted. Been right as rain ever since. IIRC there was an issue with the earlier CIMs.
  1. Indicators not self-cancelling
    By john_k_sri in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2013, 18:01
  2. Cancelling insurance
    By Adz86 in forum Insurance Chat
    Last Post: 10th December 2009, 10:37
  3. HID Warning cancelling 55W?
    By Phil MC in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2009, 13:10
  4. Indicator cancelling problem???
    By flossy1664 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 19:44
  5. Cancelling insurance?
    By Penfold in forum Insurance Chat
    Last Post: 6th January 2008, 00:19
thurlow nunn cim module
vauxhall vectra right turn indicator self cancelling before turn
vectra c indicator keeps cancelling
