Thread: Windscreen scratches
    Regular Member old cruiser's Avatar
    slough
    Default Windscreen scratches
    Has anyone else noticed how bad the windscreens are the these cars, first car I've had where after having to scrape the windscreen due to ice that you end up with some light scratches mainly seen when sunlight is on the screen if you see what I mean, been using a scraper for years and never had this occur before.
    Cheers Pete
    Mileage : 000
    It makes you wonder if the glass is "softer" so it will not chip as easily. A bit like heat treating metal the harder is is the more brittle it is (unless it is tempered back). Just an idea. But I think you will not be able to remove the scratch,s very easily.
    Mine has three chips, the maximum number of repairs permitted, so far
    Equally there are hundreds of smaller ones
    I've never had so many, I usually get one or two repairs every car
    I suspect this is more to do with the angle of the glass relative to the debris
    I have noticed that debris on the sides is well deflected, but debris in central quarter is more perpendicular than on my previous cars
    Equally, I have a lovely scratch patch on the passenger where I slipped when using an ice scraper last year
    Hopefully my windscreen will get another chip, then it will be a replacement for £60, plus I'll ask for the alternative with the sun strip
    winsford
    i would never use an ice scraper for the reason you will get scratches due to dirt that you cant see, you end up pushing the dirt into the screen, i always use cold water and use your windscreen wipers, also using the demister, when you start driving usually the friction will clear the rest.
    Regular Member poves's Avatar
    lancashire
    You can have a replacement either way , as long as you pay the excess , it's your choice.
    Repair free or pay the excess for a replacement.
    Regular Member brigrif's Avatar
    South Shields
    If you have a screen replacement due ask for the UV heat reflective top tinted screen as an upgrade. One of the two major replacement companies in the uk will do this free of charge. Its a better option but be warned it has a metallic film in the interlayer between the two sheets of glass and will not allow GPS signals through. It ok if you have factory fit sat nav but tomtom users will have to use an external gps on the rear screen. Wise advice from a windscreen specialist.....ME haha
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by andsaw View Post
    Haha. Never been in Norway have you
    Without a garage, you will guaranteed need an ice scraper here, during wintertime (as this morning, minus 4 degrees celsius and some moisture). And with a normally dirty screen, its no problem to use a ice scraper, if used correct: Appprox in 45 degrees, and _only_ push, do not pull. And the scraperblade must be of a strong material, like brass or some fibermaterial. Ordinary plastic is not strong enough, and will squeese dirt particles between the blade and screen = no good.
    On our car the screen is very scratced from the wipers. Last owner has probably use too little washer. And the screen was replaced at 70.000 KM, our car is now 120.000, so 50.000KM or 31.000 Miles... Ive never had a car with this bad quality screen.
    Bent, my name is Bent
    Mods: I polished it in september...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You can machine polish them out with the proper compound.
    Apr 2009
    Bergen, Norway
    Not in my case. Its too deep
  1. Windscreen Scratches & Cracks
    By 11mallard in forum Detailing and Car Care Discussion
    Last Post: 8th January 2012, 11:01
  2. Flat Wiper Blades & Windscreen Scratches
    By vectrasri-j in forum Styling
    Last Post: 10th December 2011, 18:20
  3. windscreen scratches
    By Morephun in forum Bodywork & Interior
    Last Post: 20th December 2009, 23:34
  4. Windscreen scratches
    By neilshaw1980 in forum Detailing and Car Care Discussion
    Last Post: 26th July 2007, 20:14
  5. Scratches
    By Matt21385 in forum Detailing and Car Care Discussion
    Last Post: 8th June 2006, 16:57
