Thread: oil leak...?
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Default oil leak...?
    Hello to all,
    Today I wanted to check oil level, and when I got off the cover over the engine, I found an engine part is wet with oil ... the wet is even on the left side of EGR's where in a hose in a hole.
    The hose is moving very strange up and down, maybe it is the reason because I`m loosing oil.
    I attach a picture to see what it is, the hose is passing over the EGR, and at the bottom end, that go into a hole, I think there is lost oil. My engine is 1.9 cdti (150) ... if someone happened to you, how to repair?
    Thank you very much.
    Full Member paul.sessions's Avatar
    leighton buzzard
    is that dark black squiggle the oil
    Jul 2009
    Bistrita
    Quote Originally Posted by paul.sessions View Post
    On the black arrows refer to you?
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    oooh, I apear to have lost oil, same engine and have the same area with oil on it, going to go and check this hose right now.
    Jul 2006
    Wolverhampton
    Nope, no leaks, the oil I have in this location is clean, I think it maybe from the last service, someone missed the filler.
    Jul 2009
    Bistrita
    now i`w noticed the oil is leaking under the vacuum pump too
    What recommended me to do in this case??
    how to stop this oil leaks???
    I want to clean all the engine because no it`s dirty and I`m not like this....
    What spray to use to clean my engine from oil leaks and all other dirty..?
    Thanks.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
