Results 1 to 3 of 3
Thread: Turbo Actuator
    Sep 2009
    Swindon
    Default Turbo Actuator
    I have removed the turbo from the car, and am wondering how far the actuator should move if I suck on the vac pipe. It moves just a few mm, should the movement be more pronounced on these i.e. a couple of cm?
    Frenchman
    scotland
    actuator should be tested with a foot pump for leaks and to test boost
    Sep 2009
    Swindon
    I am gonna drop the turbo of at my friends garage tomorrow for a second opinion but I think it's shot, when I spin the fins around it makes a grating noise and doesn't spin very freely, there is sort of a big washer behind the fins that seems loose also.
    Here are some piccys look at the carbon build up, car has done 66k and is as flat as a pancake.
    After a clean-up, this bit seems ok
    Frenchman
  1. 2.2dti Turbo Actuator Rod adjustment?
    By Innes in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 05:46
  2. Signum 2.8 turbo wastegate actuator
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 08:22
  3. Turbo actuator rod length?
    By Thom in forum Engine & Drivetrain
    Last Post: 8th January 2012, 00:27
  4. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  5. Turbo Actuator valve - Squicking Noise - cdti 150
    By digitalinkjetman in forum Engine & Drivetrain
    Last Post: 25th December 2011, 00:29
