Results 1 to 10 of 16
Thread: changing headlight bulb
    Regular Member chrissri82's Avatar
    Apr 2009
    airdrie
    Default changing headlight bulb
    hey guys, cant seem to find a how to on changing the passenger side headlight.
    any advice or tips as i was tearing my hair out with the drivers side some time back.
    Remove the washer bottle filler neck to make it easier. It just pulls out. Apart from that its just as fun as the drivers side
    Regular Member Jezzy's Avatar
    S.E
    Prefacelift model? Lift up the battery box lid, then unhook the windscreen washer bottle neck from the slam panel, then twist off the filler neck. That'll give you plenty of room. Don't listen to any doomsayers who reckon you need to remove the headlight (after loosening the bumper first).
    Apr 2009
    airdrie
    i read that but was sure that kind of drastic action wasnt needed lol
    Wait until you need to replace the offside headlamp bulb (prefacelift)
    Removing the bumper is easier, and you only need to release three screws
    Once you have removed the original bulb, make sure you can easily remove the replacement by loosing the locating lugs)
    I can now do this without removing the bumper
    Its not that bad of a job if your careful! Cover off, remove the cover and replace.
    Mileage : 000
    I can change the offside headlight bulb on mine quite easily. I have large hands too. Thought they are by nature vety dextrous. I don,t know if there is more room under the bonnet of mine seeing that it is a 3.2 V6. But heavens know how you would do the job on the 3,0. V6 Diesel, other than removing the bumper.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    yup that easy,
    as for the extent some say on the other side..pull out the airbox your in..only the top half at that
    Quote Originally Posted by ed taylor View Post
    Exactly
    I have had people suggest removing the air box, but even then it is still impossible!
    There is just no room, and on my first attempt I nearly broke my wrist as the gap is just 70mm
    I then removed the edge of the bumper, however found I had to unbolt the bottom of the headlamp
    Before refitting I modified the clip that holds the bulb in place and tested before rebolting
    The bulb is now only just held in place and comes out easily
    However I did make the mistake last time of overtightening, and knew as soon as I had done it that the bumper may have to come off again (which it did, but it was less than 10 minutes)
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Driver's side is a pain to do, but possible without removing airbox!
  1. Changing a Headlight bulb
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 17:28
  2. Changing the Nearside headlight bulb
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 21:01
  3. changing indicator bulb
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2009, 14:08
  4. Changing o/s headlight bulb?
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2008, 19:22
  5. Changing a bulb
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2005, 01:10
how to change headlight bulb on vectra 2006 elite v6 turbo
vectra c nearside indicator bulb change
