Results 1 to 10 of 14
Thread: Warning light Unknown
    Law Village, Carluke
    Default Warning light Unknown
    Hi All
    I have a situation with my vectra 1.9cdti (150). At the moment itís not causing any problems with the car but is really annoying.
    Every morning on start up or if the car has been left for a few hours
    I have a light on the dash. Itís in the box on rev counter dial and itís a car with a spanner through it (engine management light).
    It does go off after 5-10mins or a couple of miles down the road.
    At first I would switch the car off and start it back up and it wouldnít come back on again till the next morning but now when I try that the light still comes on. Once the lights off after driving or 5-10mins and I switch off the engine to run into the shop or put fuel in etc the light does not come back on unless the car is left for a few hours which it also never use to do when this problem started.
    Has any one else experienced this problem or know of this problem. I have taken the car to a Vauxhall dealer they said all they could do is reset the codes I have also taken the car to a independent garage and they could not find a problem he said the same as the Vauxhall dealer.
    Any help and advice will be much appreciated Thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If its only the first start of the day then its sounds like one or more of the glow plugs are needing replaced
    Thanks for that I will look into that
    Is it a costly repair?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    At worst about 40 quid for new glow plugs
    Just looking through the Haynes manual job seems simple enough
    Will I not need the car put back on diagnostics to reset codes after changing plugs or just wait until the morning to see if the light comes on
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    You might get the light briefly even although the problem is sorted as it stores the code. If it does this leave it and after a few weeks of driving the car the code will clear itself. You can also try disconnecting the battery to reset the codes.
    Is it starting ok or does it take longer than usual?
    I will disconnect the battery whilst I under take the work to reset the code thanks for that
    It starts fine, never had an issue starting even with the light on
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Others have had the same symptoms as you and that has been the answer. Has it just started to happen with the colder weather?
    Regular Member j1 wyx's Avatar
    Gosport-Hants
    its saying you car is due a service m8 tec 2 to turn it off, we had it on ours and julie got worried, went to the dealer and it needed a 20k service thats all
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Car with spanner in not service, car with oil can is service.
    And you don't need the dealer to reset the service light but you do for the engine fault light
  1. Abs warning light
    By Ben R in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2012, 01:28
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
  5. Oil Warning Light
    By deez_nutts in forum Engine & Drivetrain
    Last Post: 21st June 2007, 12:53
