Thread: Tyre pressures info needed.
    Sep 2009
    Consett County Durham
    Vehicle : 52 Vectra c LS 1.8
    Default Tyre pressures info needed.
    Hi,Can anyone tell me the tyre pressures for my Vectra LS 1.8,i have a manual somewhere in the house but cannot find it at the moment.Regards Martin.
    cambs
    hi
    32 psi
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    For a 1.8 LS (pre face-lift) the fronts should be 2 bar (29 psi) and the rear 2.2 bar (32psi). On full load raise to 2.2 front and 2.7 (39 psi) on rear.
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Quote Originally Posted by carpet View Post
    My manual says 32 psi all round?
    Mar 2007
    Tamworth
    That's what it says for the 1.8 in the manual with our newly aquired 2007 Vectra.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    It depends on what tyre size..our 55 Reg Facelift Club Hatch with the Z18XE engine, has 205/55R x 16's on 5 spoke alloys as standard..
    Three levels of tyre pressures suggested in the handbook -
    First - 'Normal' upto 3 passengers 29psi Front/32psi Rear
    Second - 35psi Front/38psi Rear for upto 3 passengers for improved economy &
    Third - Full load 35psi Front/42psi Rear....
    Regular Member bigbnlr's Avatar
    Belfast
    I use double the wheel size plus 2, that would be 34 for standard 16's and I've never had a problem.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by bigbnlr View Post
    Midlands Mod Shop - NFFC.
    11 Post(s)
    I tend to RTFM.
    If I used the "double the wheel size and added 2" method, then my pressures would be 36, whereas the handbook states 32.
    32 is what I've always set them at, and the wear rate is constant right across the tyre.
    Putting in 36 would not only make the ride harder, but wear down the middle of the tyre quicker than the rest.
    In short, the "double the wheel size and added 2" method isn't acurate.
  1. tyre pressures
    By waynevvti in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2012, 21:22
  2. Tyre Pressures
    By AlexGSi2000 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2011, 09:27
  3. Tyre pressures on 215 50 17
    By hinesh12 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2009, 12:41
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. tyre pressures
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2006, 11:08
