Thread: Got An idea while debadging. or Help from God required!
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Got An idea while debadging- photoshop help required!
    While Most of you where sunning it up at PVS. I got the oppotunity to start delabelling the car.
    I got 1.9 CDTI off no problem using dental floss and a hair drier. I had trouble getting the last of the sticky off the chrome strip. Any suggestions please?
    Then set to work on the Vectra badge. Got the letters off no probs that noticed that the sticky look like the colour of the car (Lightning Silver). I took a bit step back and then thought what would the car look like if I rebadged the car or put an Irmy badge on with colour coded letters. Can some one do a photoshop for me on the back end? The Griffin is comming off next!
    Regular Member ALD's Avatar
    South Lanarkshire
    Hi m8,
    I've debaged two vectra c's now and found the best way is to pour hot water over the badges first, then removed them gently with a credit card or similar.
    Once thats done I use turtlewax bug and tar remover to remove any glue left.
    Feb 2006
    Wirral
    Default Debadged but slightly different. Do I finish it?
    Cheers ALD. Stopped on the way home and got the bug remover.
    Started work on the 1.9CDTI Gone in seconds.
    Decided to whip off the Griffin. Dental floss in 2 minutes. Picked off the backing and gently wipled clean with Bug remover.
    Then started on the VECTRA which was alot more stubborn. Got so far before it went dark. However I quite like the half finished result. What do you all think....
    Debadged.....
    Still a subtle clue there:
    Up close:
    GOOD JOB MATE, THOSE BL**DY INDENTATIONS...they do finally come off..
    Feb 2006
    Wirral
    I quite like them ...very subtle
    South Lanarkshire
    I had more trouble with the vectra badge as well, just keep using the bug and tar remover, it will work
    and don't do what I done, read the instructions first lol
    i just sprayed it on and expected it to disapear but you should spray, rub it in, leave for 1min and then buff it (with another cloth)
    Here, there and every where!
    I used Autoglym chrome polish to get rid of the "shadow" Came off a treat.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    I found another way, bought a blank strip!
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Has anyone had problems removing the griffin badge, such as scratches or anything?
    not here.. done a few now..
    hot water, tesco's clubcard to remove and a mop up with some Farecla G4..
    removes all marks and blends the area nicely..
  1. debadging
    By paul.sessions in forum Photoshop section
    Last Post: 3rd September 2009, 17:36
  2. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  3. debadging
    By ballan22direct in forum General Chat
    Last Post: 15th February 2009, 09:29
  4. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  5. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
