Results 1 to 10 of 25
Thread: Drivers seat removal
    Full Member gibbon7000's Avatar
    lincs
    Default Drivers seat removal
    Hi, I need to get some repairs done to my front drivers seat, which requires it to be removed from the car. Can anyone give me any tips on doing this, do the side airbags just unplug?? Do you need any special tools etc??
    Kev
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    The seat itself is fairly self explanatry just a couple of large star bolts and it slides out, There will be a plug underneath for the airbag and the seatbelt detonater, be warned though if you unplug these and remove the seat im 99% sure you will have to then have your airbag light extinguished via tech 2 or similar when you re-fit and reconnect the plugs,
    Is there no way you can do what you need to do with the seat in the car? When its un-bolted from the floor its fairly manouverable, without un-doing any plugs.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You dont need to remove the side airbags buddy unless your re trimming the seat.
    Disconnect battery leave for 30 mins for airbag to discharge then slide the seat forward on the rails there are two t40 bolts at the back undo them, then at the side you will have another torx bolt holding the seat belt to the seat remove this then tilt the seat up towards the front and you will see the plug under the seat unplug this and pull back the seat slightly and then lift out.
    As long as you wait for the airbags to discharge you will have no warning light HTH
    Irmscher Insignia CDTI 130
    lincs
    Quote Originally Posted by bigmac View Post
    Yeah, having part of the seat retrimmed. Thats spot on big mac, thanks for that
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Well to remove airbag once its removed from car take rear fabric pannel off (just pull from bottom) then you will see iirc three 8 or 7 mm bolts its a bit tight but you can push down on springs to get better access,once you have it out theres a clip on top of the air bag just pop this up and remove wiring
    lincs
    Its not that part thats getting retrimmed, its just a bolster. so hopefully i dont have to
    Full Member Big Sig's Avatar
    Not quite true. If you don't wait for it to discharge then it could go off. As long as you do not put the ignition on while the airbag is disconnected you will not get the light on
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    But if you've cleverly disconnected the battery this shouldn't be an issue
    Regular Member Simo87's Avatar
    Jan 2008
    Middle Wallop
    to be honest i havent disconnected the battery to remove the seats and i have them out every other month to give car a thourgh clean, no airbags yet, have got the pesky light though lol
    simo
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by Simo87 View Post
    simo
    Your not risking the light coming on but risking an arm coming off lol the reason you take battery off is to discharge the airbags to stop them arming when your taking them out.
    Just because it hasn't happend doesn't mean it wont and why take the risk for a 2 min job ?
    You are right mate
  1. drivers seat
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 19:47
  2. drivers seat
    By vecgsiboy in forum The 'Off Topic' room
    Last Post: 26th May 2009, 11:20
  3. Drivers seat Airbag Removal
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 15:10
  4. Drivers seat
    By fishphone in forum Bodywork & Interior
    Last Post: 24th January 2008, 21:41
  5. Under the drivers seat!
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2006, 12:52
