Thread: Fuel Filter on 2.2DTi
    undy
    Default Fuel Filter on 2.2DTi
    Hi
    how to change the fuel filter on a 2.2dti .
    any advise .
    cheers...
    Bristol
    Vehicle : CDTI 150
    Quite easy.
    Disconnect both fuel hoses (small screwdriver) and 1 elec plug.
    Lift housing from car.
    Unscrew top.
    Lift out filter.
    Clean inside of housing with a lint free cloth.
    Replace filter, fill housing with diesel.
    Very important to fit a new seals
    When fitting the bolt its only tightened to 6Nm
    Refit to car.
    Vx recommend using a pump to draw fuel through as the diesel pump does not like running dry. Also if it doesn't start first time make sure you leave a few minutes between starts if you spend a long time cranking the engine as the starter can overheat. Its supposed to be self-bleeding
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    But before replacing the bolt into the top fill it up with diesel there too (helps to alleviate air running through the pump)
    Good luck
    undy
    manythanks for taking the time to reply.
    Paul.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. K&N filter question for 2.2dti sri
    By muther trucker in forum Diesel Engine related
    Last Post: 27th April 2012, 15:37
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
how to change fuel filter zafira 2.2 dti
