Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Signum 3.0cdti hesitant acceleration / flatspot
    Sep 2009
    norfolk
    Default Signum 3.0cdti hesitant acceleration / flatspot
    Hi all
    My Signum seems to have developed a fault.
    The acceleration is very hesitant and jerky.
    The engine is up to temprature, it almost feels like the engine is bogging down, flat spot or a dead pedal.
    I have no fault indications on the display.
    Any idea's
    Tim
    ps this is on vxon too !!
    Wakefield
    A friend of mine had a similar fault. It was to do with drop in the common rail fuel pressure. There is a Vaux field remedy out for this problem, but it is expensive - 8+ hours labour plus parts. Can't remember the field remedy no. but I'm sure someone here will know. Is your Sig still under warranty?
    Full Member Big Sig's Avatar
    That field rememedy replaces the SCV's doesn't it?
    Wakefield
    Yep, that's the one.
    Wakefield
    Have you done a pedal test to see if there are any fault codes?
    http://www.vectra-c.com/forum/showthread.php?t=81742
    However, if it is to do with fuel pressure & suction valves, it probably won't show anything (as with my friend's car), but when Vx hooked it up to Tech2 it showed a variance in fuel pressure.
    Sep 2009
    norfolk
    No it not under warranty.... this sounds expencive !!!
    Im going to try the pedal test now !
    Sep 2009
    norfolk
    ok flash code of
    10,4,6,10 P0460 - Fuel Level Sensor Circuit
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    you edit way too quick
    Sep 2009
    norfolk
    haha took me a cpl of mins to suss out the code reading
    Wakefield
    Quote Originally Posted by t1m View Post
    ok flash code of
    I can't see that has anything to do with the problems you're experiencing. Diagnosis, anyone?
  1. Signum 1.9CDTI 150 hesitating/powerloss on acceleration
    By sas_71 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th November 2012, 15:46
  2. Signum 2.2 Direct - misfire?/vibration/poor acceleration
    By Fenris in forum Engine & Drivetrain
    Last Post: 31st July 2011, 23:32
  3. Massive flatspot below 2000rpm, dpf? How to clean?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 13:19
  4. Signum 3.0CDTI - what do you think?
    By NeilB in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2007, 19:14
3.0 cdti hesitant accelerating
3.0 cdti hesitant acceleration site:www.vectra-c.com
Vauxhall signum flat spot accelerate
high pressure fuel pump 3.0cdti vauxhall vectra
