Results 1 to 10 of 28
Thread: HELP!!! key working but wont open car
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default HELP!!! key working but wont open car
    hi guys
    got a weird one here. Went to my car as usual and pressed the open button on the key and nothing.
    the light on the key comes on i have swapped the battery over and still nothing.
    i used the key to check the central locking and that works but i never opened the door incase the alarm goes nuts.
    Anybody know what the problem might be?
    also if i use the key to open the door will the alarm go off? and will i be able to drive it
    any alternatives?
    Full Member spennny's Avatar
    Blantyre
    Dont you have to open the car with the key, (long hold in open position) and then have the key in the ignition turned on ?
    May be talking carp, but worth a go
    Nov 2007
    Leeds
    nope ive always used the key button to open and close the car. and then the key blade to start.
    but the key buttons dont open the car any more? weird?
    so if i use the key blade to open the door will the alram go off?
    Blantyre
    Dont think so, not sure, just tried mine, alarm doesnt go off, turned the key twice
    Dont you have a spare key to try the fob ?
    Nov 2007
    Leeds
    i have a key but its 100 miles away as im stuck in lesta now
    did you open the door when you manually opened the door
    ill go and try the key now.
    and your sure using the key to open the car manually doesnt make the alarm go off?
    Blantyre
    lol... mine didnt mate, i turned mine twice to the left , i have an 06 plate
    Disclaimer: If the alarm goes off, and drains the battery, not my fault
    Nov 2007
    Leeds
    lol ok i except your disclaimer lol
    did you open the door when you unlocked it?
    Regular Member SRimonkey's Avatar
    wednesfield
    my key played up once.......wouldn`t remote unlock and when i unlocked it with the key and opened it the alarm went off until i stuck the key in the ignition and started the car then all was fine
    Blantyre
    Tried it again mate and the alarm went off,
    Opened the door also
    Ashington, Northumberland
    open the car with the key (dont worry about the alarm). Get in and shut the door, put the key in the ignition and switch the ignition on. now press the lock button on the key. The doors will all lock then immediately open again. Turn the ignition off, get out the car and try the buttons. the key should now be re-synchronised to the car. HTH
  1. Boot wont open
    By LeylandRick in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 12:20
  2. Boot wont open???
    By fastcarmanaic in forum Bodywork & Interior
    Last Post: 18th November 2010, 15:14
  3. Boot wont open!
    By Netstar in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 14:13
  4. Bonnet wont open
    By Apone in forum Bodywork & Interior
    Last Post: 17th September 2009, 00:03
  5. Bonnet wont open
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2006, 13:30
