Thread: front brake pad warning sensor
    scotland
    Default front brake pad warning sensor
    hi guys i have 2003 vectra c sri turbo and fitted new pads but never gt new sensor wire so i joined the old 1 but this never put the wear light out on the dash any ideas do they need earthed out on theses cars or summin?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    'Like Donny, you may not know remember me but you'll know my car. (if you are who I think you are)
    When you say you joined the wires what do ya mean? Did you twist them together to complete the circuit?
    scotland
    like manny aye i remember ya chief i moted yer motor last year i think it was good 1 at that! clean as fk lol aye joined the two(twisted together) like the auld cavys min still the poxy lights on the dash!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Probably best gettin a new sensor then bud, they are about 7-8 quid from fiskens. Normally twisting the wires together does the trick
    Regular Member sharpo's Avatar
    Jun 2009
    York
    just got my pads changed, the warning symbol in the rev counter dial is still on? there was only one wire on the nearside caliper which went back in the correct place on the new pads, is there a way to reset the indicator?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by sharpo View Post
    If you didn't replace the pads until the warning came up on the dash, then you need to fit a new sensor when you do the pads - the sensor is triggered by the disk wearing away the plastic, and once its triggered it can't be re-used. (Although you can get rid of the warning on the dash by cutting the end of the sensor and attaching the wires together to re-complete the circuit, but that means the sensor won't work again, so not recommended).
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Joining the wires together is OK, as long as you understand that the warning light will never come on and hence you need to be more aware of your pad thicknesses, instead of relying on the car to warn you of low pad.
    Jun 2009
    York
    Thanks , I understand how it works now, so i'll get a new sensor then and fit it when the warning symbol has driven me mad.
    Ta.
  1. Brake pad warning sensor?
    By Ginge7289 in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2011, 19:41
  2. Brake Pad warning sensor
    By tutfut01 in forum Detailing and Car Care Discussion
    Last Post: 15th September 2010, 14:47
  3. brake pad warning sensor/wire???
    By big rich in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2009, 16:41
  4. Replace brake warning light sensor - help
    Last Post: 12th January 2009, 18:28
  5. Brake Pad Warning Light and Sensor
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 19:18
vectra c brake pad warning light comes on when i reverse
vauxhall vectra brake pad sensor location
front brake pad censer wire for sri vectra
front pad warning light on in vectra c but only just changed pads
vectra c brake warning wire wjere does in connect
vectra brake pad wireing
where is brake pad warning light on vectra c
insignia brake pad warning
vauxhall vectra c diesel reset brake pad light
vectra v6 brake pads light come on is it rear or front
