Thread: 2013 wont eject cartridge magazine
    Regular Member malk's Avatar
    suffolk
    Default 2013 wont eject cartridge magazine
    On my 2013 I just put in a 4 disk cartrdige magazine and it won't eject. It tries to check the disks when I put it in and won't read then (only tries 3 and 4 although I did use all 4 disk slots).
    I can't find anyway to manually get the cardridge out and when I push the eject button, the cartridge comes out no more then 1 mm and pulling on the white tag won't work there is something stopping it coming out fully.
    I have removed the four allen screws on the front to see if I can remove the unit but it won't pull out.
    Anyone had same problem OR how to remove the 2013 so I can see if I can wind something when removed?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you need bracket to take out the radio or 4 small screwdrivers that fit in the holes..
    think you neede to take your ncdc apart to remove it if it wont come out.
    Full Member Big Sig's Avatar
    My 2006 did a similar thing. Open the flap and press the eject button whilst trying to carefully pry it out.
    Mine had a bit of paper stuck in the moving parts in the mag
    suffolk
    All sorted
    The magazine was getting stuck as it was in a sort of open position and the facia came off so I could then remove the magazine.
    May have happened before as the facia has plastic clips that have been snapped so facia is a bit loose.
    Thanks for tips anyway.
    Thread can be closed.
  1. CD70 won't eject sat-nav disc
    By Jebus in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2012, 01:31
  2. CDR 2005 don't eject CD
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 23:19
  3. cd cartridge stuck
    By iwtand in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2011, 10:15
  4. ccr2006 eject
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 00:20
  5. cd won`t eject
    By daveg8843 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2008, 09:51
