Results 1 to 10 of 15
Thread: its getting to me now
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default its getting to me now
    just been ouit in car and its doing my head in trying to think what the rear noise could be, when going over speed humps and some times pot holes the rear makes a clunk sound, can only be hurd inside the car not out side, and only does it now and again ie not on every speed hump, ive checked everythink i can think of in the boot,
    Have you used the search button? If not search for drop links and rad mounts. Most likely suspects imo.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Something loose in boot cubbyhole.... rear fusebox..... parcelshelf.... spare wheel well/jack/tools..... exhaust mountings..... run out of ideas.....
    Oct 2009
    Sandwell
    its the rear not front
    Quote Originally Posted by Handyandy-UK View Post
    yea checked everythink, are the exhaust mountings the rubber ones that just push on? if so there fine,
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    Check your springs, my 52 Plate did this and when i got down and dirty underneath the botton of my spring had broken off!!
    Oct 2009
    Sandwell
    Fireyfella you had same noise sort of clunk/knock? ill have a look tomorrow its only done it ever since i greased the rear bottom springs, i hope it aint broken tho,
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by chris1804 View Post
    Yep like your description, mine only did it occasionally over speed bumps but more often over pot holes. When I investigated the bottom section of the N/S rear spring had broken off completely and just sat in the recess. The N/S is the most common due to more pot holes on that part of the road and people bouncing up and down curbs.
    Let me know how you get on ?
    Glasgow
    My bet is one of the suspension arms has play in it.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Just had my rear upper suspension arms changed on mine. Wow what a difference, like yours every imperfection or pot hole speed hump it would make a right bang and crash. felt like i had my tyres at 80 psi or something there was no give in the suspension.
    The easy way to check is to put your arm in between top off wheel and wheel arch, grab hold off the tyre and pull the wheel towards you. and push back again. Mine moved loads and you can hear it clunk as you do it. You do this with the car on the ground and not jacked up.
    Both my sides were knackered. It sounds lovely now and feels softer like its not smashing over the bumps, just glides over.
    Give it a try, bet thats what the prob is.
    Thought the same on mine but it turned out to be the rad mounts.
