Results 1 to 10 of 13
Thread: startup grrr noise
    jilava
    Default startup grrr noise
    it's a 1.9 cdti 150 engine. Noise started maybe 3 months ago, and it doesn't matter if engine is hot or cold. I made a video with the noise at http://www.youtube.com/watch?v=jYcLlhiSGcw
    what could be causing it?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Hard to tell with the quality of Youtube vids, but could be the usual noise that occurs before the oil gets about... when was the last time it was changed, and what oil is in it..?
    jilava
    bought the car about 8 months ago and made 8000 miles with it without changing the oil, so I don't know what's in. plan on doing a full filter and oil change as soon as possible with vauxhall full sinth 5w30.
    jilava
    here's another one, this is with the doors closed http://www.youtube.com/watch?v=avDCawXIS9Y
    Regular Member Grahamy's Avatar
    Ryton
    sounds like the starter motor is is not dis-engaging quickly enough
    jilava
    that's what I was thinking... where is the starter located on the cdti 150?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi A
    its on bellhousing,jack up car remove engine top cover and lower cover,also right hand side splash cover.uncouple battery (make sure you have radio code)remove starter earth cable,and coolant pipe bracket,then remove starter bolts.
    lower jack remove coolant expansion tank,unclip vacuum line,2 heater hoses,disconnect starter cables ,unclip alternator wiring harness ,remove starter uphill.refit is reverse ,
    inspect starter gear drive for wear if the teeth are ok clean gear sliding shaft and grease with copper slip,when you pull and turn gear it should snap back to rest possision
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    wouldn't worry they all do the light clatter. put a diesel pump on one at work for it, stopped for 1-2k then came back
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Mine did the GRRRRRR noise on startup after i had done a long journey but after 2 days it went away,i thought at first it was the starter motor but it hasnt done it again (touch wood)
    Seems to only do it after a long journey 250 + miles
    Irmscher Insignia CDTI 130
    jilava
    thanks jonny, that seems pretty complicated...
    matt and bigmac mine does it every time it starts now, didn't do it when I bought it, I will check the starter motor as jonny suggested.
  1. Scraping noise on cold startup.
    By erni3wi5e in forum Engine & Drivetrain
    Last Post: 18th March 2012, 14:20
  2. Irritating Whirring Noise... grrr 1.9cdti (120ps)
    By Meady in forum Engine & Drivetrain
    Last Post: 6th April 2011, 07:30
  3. tapping noise on startup when cold
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 09:32
  4. knocking noise on startup
    By simon7257 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 17:17
  5. Groaning Noise On Startup
    By VauxVeteran in forum General Chat
    Last Post: 24th December 2006, 04:11
