Thread: temp gauge issue on 1.9 cdti
    Regular Member robk6112's Avatar
    Halifax
    Default temp gauge issue on 1.9 cdti
    Morning everyone
    I drive 18 miles to work and back every day and I have noticed recantly my temp gauge hardly ever moves of the bottom. Is this normal in this weather for a 150 cdti. My old 2.2 dti ran much warmer?
    I have done an airbox mod and fitted a k and n and a tuning box if this makes a difference and the car has been serviced last month
    Cambridgeshire
    Mines the same mate. I drive about 12-15 miles each way to work and the temp gauge will almost reach 80.
    If it's really low you might need a new temperature sensor mate.
    Regular Member Grahamy's Avatar
    Ryton
    Mine takes a while to move too, just under 10 mins , its normal
    West
    Had this on my old dti, a new thermostat cured it
    Leicester
    There was an issue with pre-facelift 1.9 CDTi's where the thermostat did'nt operate properly. A new unit should solve this.
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Pretty normal for a 1.9cdti I think. Mine takes about 10-12 miles of fairly nippy driving to reach 'working' temperature. Longer in the winter. Makes for a fairly slow heater and screen demist these chilly mornings!
    Halifax
    Quote Originally Posted by boba View Post
    yeah i was frozen this morning for a hole hour!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    That points to needing a new Thermostat then, as my needle hardly moves, but the heater heats up really quickly pointing to a dodgy temp sensor.
    Regular Member speaker's Avatar
    Jul 2009
    Almere- Holland !
    It's not normal for a engine to take 10-15 minutes to reach 80 !
    Mine had this too.
    I went to the Vx-dealer and ordered a new thermostat ( wich includes a new sensor as well ! ) costs around 55Pounds and 1,5 hours of work !
    Now it runs to 85 till 90 within 5 minutes from a cold start !
    The needles never drops under the 85 ! ( when engine runs ofcourse ! )
    The old one is a bit different then the new one ( and a other brand )
    The old one:
    the new one:
    incl. sensor !
    Halifax
    Thanks everyone -ill order a new one on payday!
  1. Possible temp gauge issue??
    By mcpitman in forum Engine & Drivetrain
    Last Post: 9th February 2012, 23:50
  2. Temp gauge on my 1.9 cdti (150)
    By winton40 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st April 2011, 14:19
  3. cdti 150 temp gauge sits at 70 most of the time?
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2011, 13:19
  4. 1.9 cdti 150 temp issue
    By dubsrus in forum Engine & Drivetrain
    Last Post: 7th September 2010, 08:58
  5. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
vectra c temp gauge hardly moves
vectra 1.9 ctdi temp gauge
