Results 1 to 10 of 23
Thread: Lost my clutch, first ever!
    Default Lost my clutch, first ever!
    My car has always had an odd loss of power when trying to overtake
    I reported it twice in 2007 but the dealership was never able to actually find a faulty component
    Basically it was like clutch slip above 3000rpm :
    Come down a gear, lift the revs, reengage clutch, floor it
    However the revs would go straight to 4000rpm, then come back down down, then back up again
    I was able to recreate this and demonstrate to the area technician, but he was unsure what the cause and suggested it was probably due to the gearbox being on the limit of the torque it could handle
    However yesterday it starting doing it all the time!
    So I revised the job on which the car was already booked in for today (crunchy offside brake)
    Then last night on the M80 at Crowwood Roundabout I lost all gears, managed to coast to a parking bay
    Prior to that the clutch was working perfectly, with the bite point at the expected level
    Phoned the AA and was given the option of roadside repair or recovery, but chose recovery as the car is booked in for this fault to be looked at
    Equally, quite glad this has finally gone permanent AND destroyed the clutch, and just 3 weeks before the warranty expires
    Might finally find out what the issue is
    Sadly, I doubt a courtesy car will be available, so looks like I will be arranging my own hire car
    Equally, could be a few days...
    I've driven nearly 500,000 miles in 4 cars and never had a clutch fail
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Juat what sort of 'technician' was that? Did he think that the gearwheels would somehow slip over each other at high torque? Sheech!
    Full Member Big Sig's Avatar
    Sounds just like a worn clutch. I suggest you find another techy!
    Regular Member scottyd's Avatar
    paisley
    any news yet?
    Quote Originally Posted by scottyd View Post
    any news yet?
    I believe BA have announced more job cuts
    Dealership firstly inspected the clutch
    The hydraulic control was found to be working correctly, this corrected the disengaged clutch
    They then took it for a roadtest and initially thought the problem was solved, until they went to 3rd gear, when the clutch would not engage and suffered the same symptoms I had previously been reporting
    On the way back they then also lost 2nd gear and had to crawl back in 1st gear, before the clutch went again, meaning they had to push it along the road!
    The gearbox has only just come out
    However the gearbox is a different story and it will probably need to be replaced
    It would appear it overheated and damaged the clutch
    The dealership has requested the area technician attend to inspect, so as to ascertain why there is so much damage to the gearbox and transmission components
    Sadly this will leave me without my car until at least Wednesday (inspection plus parts)
    paisley
    you really couldnt get any funnier could you?
    I try my best lately
    3 years of being helpful and not many thank you's does it to a bloke
    Edinburgh
    I thought it was quite funny, but it would appeal to my dry sense of humour
    m8internet, glad it at least happened before your warranty expires.
    I suspect VX Retailer Warranties were hoping it was the clutch, as they claimed it was one of the few components NOT covered by my warranty
    However I phoned them back after checking my policy and the clutch IS covered (one of their few policies that does cover "wear and tear")
    Equally, if this claim goes ahead this would be the final one permitted under the policy, having now reached its maximum claim value limit
    Any more after this, they will be declined, and car considered for "buy back" as outlined in the policy
    I would probably not go that path, depending on how much the repair quote was
    I have budgeted for servicing, repairs, and maintenance of £3000 over the next 12 months when the warranty expires
    Anything left over will be used as deposit for next car in late 2010
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. im lost
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2010, 14:57
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  5. lost one touch window close after clutch fitted
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2008, 17:18
