Thread: Clutch Judder?
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    confused Clutch Judder?
    Anyone knows what causes clutch judder or on a 1.8XE 52000 miles.
    Seems to happen randomly or when releasing the clutch fairly quickly.
    Could this be a sign of a failing clutch or a DMF issue? or something else?
    Thanks for any help or suggestions.
    preston
    Don't think !.8 petrols have dual mass flywheels, suspect pressure plate or friction plate issue
    Apr 2009
    Lancs/Manchester
    I will be happy if it doesnt have a DMF, i have read plenty of posts about these and none seem a cheap fix!
    Could it be oil or something getting on the cluth "face"?
    preston
    possibly but unlikely. I had a car with a similar problem so I tried to 'bed it in' sowt a speak as it was a new clutch so i gave the clutch some heavy abuse by revving hard and slipping it a lot and it did do the trick. i was loathed to take the clutch out again and replace, not really scientific but it did work. Juderring though can also manifest from worn or loose engine mountings which again i would suggest is unlikely.
    Apr 2009
    Lancs/Manchester
    If im honest the car had been standing a while unused (about 3-4 weeks when i noticed this had started and i have only recently started using the car again on a daily basis so maybe its one of those things that will clear itself with use?
    preston
    I personally wouldn't worry about it, sounds like it will go away. I'm pretty sure yours won't have a dmf fitted as they are used on diesels to damp torsional vibration and prolong gearbox life.
    Full Member Big Sig's Avatar
    there have been quite a few 1.8's with that issue on here. Have a search.
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    Think theres a modified clutch assembly for these
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Clutch judder
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 19:58
  2. 1.8 clutch judder
    By tony in forum Engine & Drivetrain
    Last Post: 1st January 2012, 01:54
  3. Clutch judder
    By yessof in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2009, 17:10
  4. 1.8 vvt clutch judder
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2007, 19:43
  5. clutch judder
    By brian75 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 13:30
