Thread: Hub adaptors or wobbley bolts?
    Chesterfield
    confused Hub adaptors or wobbley bolts?
    Can wheels with a pcd of 108 be fitted to a vectra with a pcd of 110?
    If so is it hub adaptors or wobbley bolts I need?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    yep with wobbly bolts. make sure the center bore is not too small. i take it your using ford wheels
    Chesterfield
    Well I got offered some brand new 20" alloys with tyres for £400!!!!! -They look like Irmscher wheels. The guy says that they are off a Peugeot?
    Jul 2006
    Northampton
    Trim : Sri
    check the pcd if they are from a peugeot. with wobbly bolts you can adjust 2mm so 5x108 or 5x112 will fit otherwise you need adaptors. it think the only ones off the shelf are vx to bmw so you will need them custom made.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by rolyat View Post
    They probably are irmscher wheels but they will NOT fit if they are from the Peugeot 4007 (the 4x4 one) as the pcd is 114
    http://www.4wheelsnews.com/peugeot-4...e-by-irmscher/
    Regular Member hagga's Avatar
    kingswinford
    I'm using wobbly bolts but I'd say if you need to change offset by 20mm or more go for hub adapters
    Regular Member the stig's Avatar
    Sep 2009
    Yorkshire
    Peugeot use Et15/20 so you would have to get the wheels machined to bring the offset in or they will stick out too far
    Oct 2007
    Shropshire
    TBH I know this is not recomended but if they are 108 they will probably go on anyway. I have put vectra wheels (110) on a laguna (108) and they were fine...
    Oct 2007
    Shropshire
    Forgot to say I take no responcibilty if you bolt them on and they come off!
  1. Which speaker adaptors
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2012, 19:50
  2. For Sale: 4 x10mm spacers, spigots, longer bolts and locking bolts
    By 6009tristanb in forum Parts for sale
    Last Post: 25th September 2011, 20:02
  3. Where to get fascia adaptors?
    By siross in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2008, 22:01
