Results 1 to 3 of 3
Thread: Passenger window control on door...
    Glasgow
    Default Passenger window control on door...
    The switch on the passenger door wont bring the window down. Works fine from the switch on the drivers door so I know the mechanics are ok. If it's a faulty switch is this an easy replace or a door off job ?
    Nottinghamshire
    These buttons can be arkward if not used regulary. Suck/blow/brush the dust out from under the buttons. Failing that, try some electrical contact cleaner - as long as you wipe the surplus up afterwards so it doesn't run everywhere.
    If the switch doesn't light up, pop it out of the door and check the electrical connector is firmly connected. You could use some electrical contact cleaner there as well if it looks dirty.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Nicolas View Post
    I had this, switch wouldn't open the window but the door lock and boot unlock switches still worked.
    How I fixed mine was like this;
    Use a thin flat blade, I used a butter knife from the kitchen , pop the switch surround out the door and unplug the connector, then with the knife pop the switch out the surround plate. Then carefully with the knife again gently prise the switch apart from either side at the back. Then you'll have the buttons, rubber "contact" pad and circuit board. spray the lot with super solve/contact cleaner, including the contacts on the boot pad, dry it off and put back together and back in the car.
    Took 10mins total and now works like a dream, well mine does anyway
  1. Passenger door window and mirror electrics not working. Any ideas, thanks.
    By MT82LFC in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2011, 01:09
  2. front passenger electric window control stopped working
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 10:47
  3. Replies: 7
    Last Post: 6th July 2007, 11:10
