Thread: front window demist button
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default front window demist button
    just a quick question you know the window demisting button (front), i thought if i have the blower so its blowing out the front vents, and i press the window demist button for the front i thought it still blows the air out the front vents as well as blowing the window to demist, or am i wrong
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no mate all to the screen
    Full Member paul.sessions's Avatar
    leighton buzzard
    Oct 2009
    Sandwell
    May 2006
    scotland
    On front demist, you do get a small amount of air comming through both front vents at the extreme left and right sides. The theory, I guess, is that most will have these vents positioned so that the air is bouncing off the front door windows.
    Worcs/Staffs/Westmids (ish)
    I found a 2kw fan heater sat on the centre console for 2 minutes does a much better job for demisting and de-icing
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Quote Originally Posted by Birchy63 View Post
    Especially if you've got a 1.8vvti which takes about half an hour to get even luke warm!
    Paul.
    Snowman, you got your ears on?
    Full Member Big Sig's Avatar
    Your wrong there are some small vents above the normal ones to demist the side front windows which will still blow.
  1. heated rear window button interferes with radio reception
    By diesel_carp in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2012, 17:43
  2. Central front demist grill
    By MattBrowning in forum Bodywork & Interior
    Last Post: 31st May 2012, 21:59
  3. electric window button
    By sdhowe80 in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2010, 21:51
  4. Replies: 9
    Last Post: 15th February 2010, 15:29
