Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Air Box mod
    Sep 2009
    Glasgow
    Default Air Box mod
    http://www.vectra-c.com/forum/showthread.php?t=15122
    Just done this an hour ago took 5 min and and initial test drive seems to have cured the flat spot i was having in first gear under 1500 rpm pulls better with lower revs and seems a bit smoother, also watch the plastic clips as i broke the bottom left hand one taking it out tried so hard not too as it was mentioned in a previous post, but all going well I wont need to put it back in and if i do a little bit of super glue will do nicely. Also will the ecu learn through driving that there is more air flow and auto adjust or will i need to disconnect the battery for it to learn.
    WGAF#5
    it will auto learn through driving - it will take longer than disconnecting the battery = but less hassle as you dont need to recode the radio and relearn the auto shut/ open on the windows - and its more fun as your driving it rather than standing around for 10 mins waiting for everything to clear out/down
    Sep 2009
    Glasgow
    cheers for the info, I take it you also felt a difference when you modded yours.
    Worcs/Staffs/Westmids (ish)
    When you take it for a service..... expect them to get on their high horse saying "people think it gives more power, but it's nonsense".
    A response like this will normally shut them up, "no it doesn't increase power, it simply alters the torque characteristics to provide a more linear power delivery, it was only fitted in the first place to get the car to compete on fuel economy with it's nearest rivals like the Mondeo"
    Some truth, some waffle.... But they look at you like "oh crap this guy knows his stuff"
    Sep 2009
    Glasgow
    when you mention fuel economy will this mod decrease fuel economy or raise it slightly like I have read in other posts.
    Sep 2009
    Glasgow
    anyone notice a decrease in mpg after this mod.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Nope.... still getting around 28-30 mixed average in my 3.2 GSi..... and that's with airbox mod done and K&N panel filter fitted.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Quote Originally Posted by Handyandy-UK View Post
    I must be doing something wrong, last time I worked my MPG out, I got about 33 MPG in a 2.2 16v, motorway and short urban drive :s
    Sep 2009
    Glasgow
    thanks for the replys, will keep an eye on mpg.
    May 2008
    Derbyshire (south)
    I had a slight increase on mpg, not alot though but if air is flowing better, then it should do imho
