Thread: Windscreen Condensation
    Regular Member johnny1983's Avatar
    Ryton, Gateshead
    Default Windscreen Condensation
    Hope someone can help.
    I've had my car for a few years and have just started notice the condensation along the bottom of my winscreen. Is this normal?
    The blowers demist the screen but doesn't touch the condensation.
    Could this be a window seal?
    Should i add it onto my list of warranty work to be done?
    Cambridgeshire
    Have a look at the pollen filter mate, it might be clogged up with stuff or holding water?
    Ryton, Gateshead
    never thought about that - i'll have a check when i get in from work.
    Thanks again for prompt help.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    mine suffers really bad from condensation in the winter ...pollen filter is clean and drain holes are free also the rear window does the same
    i'v checked everywhere and can't see any water or damp patches in the car at all
    Regular Member RLFH470's Avatar
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    I've just started getting this with my rear windscreen in the morning and early evening but it covers the whole screen. Could the pollen filter be responsible for this too? If so, how do I go about checking it?
    Aug 2009
    LEEDS
    mines just started this aswell, mainly when it is or has been raining
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    Just found a Vectra-C.com 'how to' for replacing the pollen filter so will have a look when I get time.
    Worcs/Staffs/Westmids (ish)
    I just don't think they're very well ventilated at all.
    Stick the aircon on and set it to recirculate for 10 mins, that'll sort it out for a day or two as it dehumidifies the air that's inside the car instead of drawing fresh damp air in.
    WGAF#5
    for those of you without leaks still suffering - do you have rubber mats ??
    if so then one of the main problems with rubber is water/moisture will not absorb into it like it does with carpets - when the car warms up the moisture evaporates and wanders around your car happy in the knowledge that when it cools down its going to stick to the largest coldest thing in there ....yep front and rear screens -
    - when you get back into the car and turn on heated rear screen and blowers on the front the process starts all over again - evaporates and waits till cool to condensate again.....
    the best thing you can do is to dry the excess moisture from the screens (front and rear) before you do anything else - dispose of the damp tissues /cloths (in a bin not in the door pocket)...then run the ac on recircuate to help remove any additional excess moisture from the car - then invest in carpet mats as the problem seems to not happen as much as the excess moisture is absorbed rather than sitting on top of the mat
    North East
    Quote Originally Posted by neverlandandy View Post
    Where exactly are the 'drain holes' you mention?
  1. Insignia Condensation
    By bigmac in forum Insignia Chat (READ ONLY)
    Last Post: 25th January 2013, 18:06
  2. Insignia Condensation
    By neverlandandy in forum Insignia Chat (READ ONLY)
    Last Post: 25th January 2013, 14:11
  3. Condensation within the car
    By gaz4d in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 23:49
  4. condensation inner surface of windscreen
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2009, 06:19
  5. Windscreen Interior Condensation
    By AndySkinner in forum Bodywork & Interior
    Last Post: 11th February 2008, 14:15
