Thread: Update on tapping noise
    Cambridgeshire
    Default Update on tapping noise
    I recently mentioned issues with a tapping/ticking noise on my CDTI (150) on tick over. Sounds like there is a bolt or screw rattling around in the engine. However, when the car is driven and warms up noise is gone?
    Could this be a gasket of some sort? (exhaust manifold?)
    Mar 2007
    North East
    My 150 had rattling noises from the engine for ages, found a couple of bolts had worked loose and were trapped next to the block. Can't remember where they were bar at the front but I know they were sods to recover plenty of knuckle rapping and cursing.
    Worcs/Staffs/Westmids (ish)
    Something to do with the head/valves I would have thought, when and engine gets warm the dimensional tolerances change and noises like that tend to disappear.
    Cambridgeshire
    Quote Originally Posted by Birchy63 View Post
    So probably got something to do with my inlet manifold being knackered and swirl valves not working properly then? (recently found out at the same time that swirl valves are beggared)
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Common problem on the Vec-B giving a similar sound was a cracked exhaust manifold, broken studs or blow-by on the gaskets.
    Very nosiy when cold but as the exhaust manifold heats up, the crack/gap disappears as the metal expands and "seals" itself.
    I know it's a Vec-B problem but might be worth checking on your Vec-C.
  1. Slight Tapping Noise
    By spennny in forum Engine & Drivetrain
    Last Post: 28th March 2011, 21:03
  2. Tapping noise
    By james tierney in forum Troubleshooting
    Last Post: 7th April 2010, 12:28
  3. tapping noise
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 11:50
  4. Tapping Noise
    By jay146 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 15:28
  5. Tapping noise at 60-70 mph.
    By Andrew Hambridge in forum Petrol Engine related
    Last Post: 31st July 2007, 15:00
