Thread: Rear Brake Wind Back tool/cube
    Wales
    Default Rear Brake Wind Back tool/cube
    Anyone succesfully used this wind back 'cube' on the rear of a vec-c?
    http://cgi.ebay.co.uk/DRAPER-BRAKE-C...item5636ae2c2f
    Sep 2009
    Swindon
    Hi m8,
    No it doesn't fit you will need to get the for the vectra C. I tried without success and ended up paying £10 to get the right fitting.
    Frenchman
    Oct 2007
    Shropshire
    Again they do not fit, you need the proper tool.
    I have done mine by adding preasure with a g-clamp and winding it (carefully to avoid damaging the piston and seal) with mole-grips, but you need to take the calipher off and have at least one assitant to do this properly.
    If you push the calipher in without winding it you will break it. If you wind it and don't push, you will break it. Only use this method if you've done them before and kind of know how much to wind and push if you know what i mean!! I take no responcibilty for anything you do!!
    Wales
    Thanks gents - I will fork out for the right wind-back tool!
  1. Rear brake calipers wind back tool - Herts
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 21:24
  2. Brake piston wind back tool?..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 15:47
  3. brake calliper wind back tool
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 13:34
  4. Draper 33606 Caliper Wind Back Tool Kit
    By s1nglef1sh in forum Handling & Braking
    Last Post: 3rd April 2009, 17:29
  5. Piston Wind-Back Tool...
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2008, 14:10
will brake piston cube fit vectra
vauxhall vectra brake caliper wind back tool
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
