Thread: Help & Advice Urgently Needed
    cheshire
    Unhappy Help & Advice Urgently Needed
    My 2.2 Vectra has deceided it will only start about 5 minutes after i put the key in, basically it doesn't even crank over and the eml is on i then go inside have a cuppa go back out turn the key and it will start, i took it to a vauxhall specialist and they told me it was either a CIM fault or a known problem with the abs plug which was a dealership only fix, apparently it would of been recalled under warranty but mine wasn't taken back.
    I left the the vx specialists and went to my nearest dealership, a whole week had past and in that time i'd received one phone call from them telling me they were keeping it over night, everytime i phoned them they told me everything from there was a loose wire in the abs plug to it might need an abs pump, today i walked into the dealership and they have now told me it could be the ECU and that it was £700 and it still might not fix it, basically i told them too jog on and now have the car back still with the same problem, has anyone else had this problem? please help
    cheshire
    confused
    anybody?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by lfcfan85 View Post
    when it doesn't start you could wriggle the abs plug and if it doesn't start then you could tick it off. does the eml flash?
    cheshire
    Quote Originally Posted by mattv6diesel View Post
    the eml light stays solid in the bottom right corner and the mil light (picture of orange car with a spanner thru it) in the middle of the dash flashes
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    what engine is it aswell sorry petrol or diesel? if a warning light flashes might be the cim problem as flashing warning is normaly a imobilser problem
    cheshire
    its a 2.2 petrol.
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    go to a local garage and get it plugged in to see the error code. or buy an op-com. don't go to VX as they will charge £55 for the 10 seconds.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Unplug the ABS plug, give it a clean and plug it back in. Flashing EML is immersions I believe so check that system also. Dont go to a none VX garage for the codes to be read unless they have Tech 2 or equivalent or you wont get the proper fault codes.
    scotland
    rubbish fault code read with decent software will give code and txt!
  1. 2.0dti Diesel pump advice urgently needed
    By ads3 in forum Diesel Engine related
    Last Post: 14th June 2011, 15:33
  2. heater help and advice needed urgently
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 21:40
  3. Gearbox Oil Level Advice Urgently Needed Please **
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 19:02
  4. needed urgently
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 12:42
