Results 1 to 10 of 18
Thread: Change Glow Plugs on 120 CDTI
    Oct 2009
    _
    Default Change Glow Plugs on 120 CDTI
    I have about 2 hours to change my glow plugs over tomorrow so I thought I'd do a bit forward planning. Am I gonna need female torx bits and deep sockets, the only tools I haven't got? Any info welcomed - cheers.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    deep sockets bud but why are you changing them
    Oct 2009
    _
    Well it's not been starting in the cold mornings very well and it's draining my battery trying to start it.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    are you getting a warning light as they are monitored for a failure. is not then i would check else where as u might be wasting your money
    Are you VXR Enough
    13 Post(s)
    like leak off pipes??
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    whats it doing cranking and not firing?
    Oct 2009
    _
    There's no warning light, it's due a service anyway so I thought I'd change them. With it not starting though I've really got to sort it asap as it's the family car. It starts fine when warm, it just seems to be in the cold mornings. It turns over but takes a while to fire and after about 5 attempts the battery dies So I'm putting the battery on charge overnight and taking a half day to replace the glow plugs tomorrow. I did notice today after a jump start -steam coming from the engine bay, I hope it's not related. It went away after a little run - temp and water levels are OK.
    Any advice on the glow plugs then or are they straight forward?
    Are you VXR Enough
    13 Post(s)
    they are staight forward best to get a deep socket though as they can be very tight
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    take the egr valve of to get to cyl 4 and for cy1 & 2 their is a small fuel block on the manifold that might need to come off its held by two t30 torq bolts. even then a little fiddley
    Oct 2009
    _
    Cheers guys, I'll let you know how I get on and if it sorts out the problem.
  1. how to change glow plugs on 1.9cdti
    By mr.4dil in forum Diesel Engine related
    Last Post: 11th May 2011, 20:01
  2. Glow plugs change
    By deeks in forum Diesel Engine related
    Last Post: 21st April 2011, 15:47
  3. 1.9 cdti 150/ How often should you change the glow plugs?
    By richiem in forum Engine & Drivetrain
    Last Post: 14th January 2011, 15:16
  4. change glow plugs
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2010, 17:42
  5. how do i change the glow plugs
    By tim wood in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:25
how to change glow plugs vectra c
