Results 1 to 10 of 17
Thread: Cam belt change urgent question
    jilava
    Default Cam belt change urgent question
    Hi, I'm changing the cam belt and water pump right now following the excellent how to wtitten by Nev -thanks - and have a question: wich way should I turn the crank shaft to align the notch on the wheel with the noch on the semi cover? clockwise or anticlockwise?
    thanks
    jilava
    forgot to mention CDTI 150ps engine
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    clockwise if its timed correctly.
    jilava
    thanks Dose, I ran into a problem. Can't get off the engine mount that's bolted to the engine. It's got 3 bolts that I removed but It won't budge. Any ideas?
    Quote Originally Posted by andreitone View Post
    are you sure their aint a fourth bolt, i cant remomber off hand?
    jilava
    I can see only three...
    jilava
    found the fourth bolt got it out but still the engine mount stays on the engine, but it has a little play now, anyone know if there's a fifth bolt holding it to the engine?
    it's dark outside now and started to rain, think I'll leave it for the morning...
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    There one underneath an idler/pulley i think
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    jilava
    thanks plasma, got that one too, but now I 'm having trouble removing the torsional vibration damper I think it's called, it's the big wheel with 4 torx bolts that drives the aux belt and it's on the crank shaft. I unscrewed the 4 bolts but it won't budge... any tips on that would be great. I really appreciate the help guys.
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    if you've got the 4 bolts out this i think its just friction holding it on
  1. URGENT MOT tomorrow rear seat belt not latching
    By BBMadness in forum Bodywork & Interior
    Last Post: 15th November 2012, 23:34
  2. Urgent Help needed please, 150 belt broken
    By Mopar Man in forum Diesel Engine related
    Last Post: 11th June 2012, 07:47
  3. Urgent Help! Alternator Change...
    By Danlisa in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2010, 16:06
  4. Urgent Help!! Fan/auxilliary belt fitment
    By buggy_666 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 16:05
  5. Urgent....Belt tensioning bolt
    By JSM414 in forum Engine & Drivetrain
    Last Post: 9th October 2007, 21:34
