Results 1 to 10 of 11
Thread: Hand brake recall
    Regular Member axelf's Avatar
    chester le street
    Default Hand brake recall
    Just been to the local dealers to have th recall done on the hand brake........Feels like there is more tension on it now.....i didnt even know this had nt been done already.....It only took them 20 mins....
    Regular Member bigbnlr's Avatar
    Belfast
    how would you know if it hasnt?
    asdasd
    You phone them and ask them if it needs to be done.
    Belfast
    cheers must give them a shout
    chester le street
    Hello m8 , thats all i did just gave them a ring....Mine is a 54 plate and i have had it 2 yrs....and it had nt been done asked if anythin else needed doin and there wasnt.........
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    im gonna give em a ring tommorrow as well
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    look under the hand brake arm and you will see a silver clip/spring with a curly end, took my dealer 2 mins to do and me 5 to remove. hated it felt like a tranny van.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Hi Wizard..You'd need to remove the handbrake release button, grip & lower trim panel to do get at it don't you???? If so If so I'd be interested to know how difficult it is to remove the plastic pivots from the lower plastic trim panel.....I am interested in the handbrake issue I have....the attached post will give the reason why...any advice would be gratefully received....cheers
    http://www.vectra-c.com/forum/showpo...05&postcount=4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    no, the clip/spring is easily fitted by hand and only takes two minutes no more!! removal is a little fiddly, push seat right back + lower. press brake pedal and apply handbrake firmly, look under the handbrake and you will see a silver v shaped clip/spring, pliers are best to jiggle unclip and remove. obviously it is a safety enhanced part mainly to aid persons not applying the handbrake correctly so if your happy with the feel leave it .
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    here you go some pics of the cilp, although you will only be able to see the end with the curl/loop.
  1. Post hand brake recall
    By beachlife in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2009, 13:26
  2. Hand brake recall + Turbo
    By renry in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2009, 22:47
  3. hand brake recall
    By 30ltr nutter in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2009, 16:07
  4. Hand Brake Recall
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2008, 09:19
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
vauxhall vectra handbrake recall
