Thread: z18xe z18xer
    Regular Member pitsmoor21's Avatar
    Apr 2008
    sheffield
    Default z18xe z18xer
    Hi im needing a new engine and have been offered one cheap its out of a 2008 vectra engine code z18xer mines a 2004 vectra with the code z18xe would the new one fit and work
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The new one is VVT so it wont be a straight swap. I'd keep to what you got mate TBH.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you could swap the engines which i think is a straight swap but its the electronics you would have to worry about you would need the ecu the keys the immob chips etc etc
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    It would be easier and cheaper if you bought your original mate the Z18XE
    Vehicle : SRi
    Mileage : 137000
    you could swap the engines which i think is a straight swap but its the electronics you would have to worry aboute you would need the ecu the keys the immob chips etc etc
    You would need to tech 2 everything as well and with the XE being a half can and the XEL being Full Can you may run into bigger problems. Dont get me wrong, it Danboy can drop a 2.0T into his Z18XE car then I'm sure you can drop in a XEL but it expensive and a lot of work.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    z18xe is a normal 1.8 but the z18xer has varible geometry cams so you will need loom ecu and everything and it only gains 15-20 hp. don't bother normal z18xe
  1. 1.8 VVT Owners HELP! Z18XER
    By stephengreen1980 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 20:44
  2. z18xer to z18xe
    By jimbo1987 in forum Engine & Drivetrain
    Last Post: 16th November 2012, 16:22
  3. Which engine do I have? z18xe, z18xel or z18xer.
    By barry087 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 19:41
  4. Z18xe / Z18xer?
    By J4M35 in forum Petrol Engine related
    Last Post: 4th August 2011, 21:50
  5. Z18XE Vs Z18XER?...
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2009, 21:36
z18xe swap with z18xer
vauxhall signum 2005 z18xe or z18xer
vectra c z18xe and z18xer
z18xer vs z18xe
