Results 1 to 10 of 14
Thread: Rear upper control arm
    Bedfordshire
    Default Rear upper control arm
    Hi I have a problem with my vectra the rear tyres have worn UN even they seem to be scalloped if you run your hand over the surface you can feel the undulations they look ok to the eye. The tyres are droning like mad and my local Vauxhall dealership says itís normal they canít find anything wrong with the car itís a problem with the tyres.
    They are Goodyear F1s with about 6-7mm of tread. I have looked at the rear suspension and when the car is on the floor I can feel some movement when you pull the top of the wheel towards yourself. Am I correct in thinking that the upper control arms are worn? Both sides are the same and I canít hear any knocking.
    I dont want to replace the rear tyres and find this happens again.
    The car is a 2004 vectra gsi with 57K on the clock.
    Any help would be much appreciated.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you tried swapping the front tyres to the rear?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Good idea, my tyres drone like a goodun between 50 & 55, otherwise fine. Can't remember the make, some rubbish that was on it when i bought the car.
    If the upper control arms are shot you'd get a clank when on a bumpy road, and you should get a metallic clank when you pull on the top of the wheel. My left hand wheel definitely did this and moved about an inch, the right less movement with no noise but I changed both at the same time.
    Someone else on here will be able to tell you if it's the bearings or not, I've not experienced these issues yet.
    Bedfordshire
    Yes I have rotated the tyres to the front and the noise changes. You can feel the tyres are scalloped when you run your hand over them.
    I donít want to replace the tyres when I know it will happen again.
    Are you VXR Enough
    13 Post(s)
    the wheel bearings drone anyway
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    both arms need replaced if their is play mate..another vauxhall ba;;s up..if you replace the tyres they will only wear put quicker as the problem worsens.
    Bedfordshire
    I would of thought the vauxhall dealer should of picked this up because it specifically went in to check the rear suspension first time and I asked about it again when it was serviced.
    Regular Member dudley6623's Avatar
    Sep 2009
    skegness lincolnshire
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    Thumbs up
    I had the same prob with my vectra c, play in both rear wheels when you grab the tyre and shake!!! got these of ebay, fitted and sorted the problem!!! Item number 220435226389 hope these are the right bits
    Bedfordshire
    Are the control ones on e-bay an good ? Lmf want £30 pound each are they a proper gm part ?
    Sep 2009
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    They fixed my problem great, i got a quote of the stealer of £70 plus vat so shoped around and found those ebay 1s, baragin price and they fit fine, even have the holes in that the a.b.s sensor wire (think thats what it was)clips too!!!!
  1. Rear upper control arm bushes
    By valleyboy in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2013, 09:13
  2. Rear Upper control arms help
    By enjoy_life27 in forum Suspension, Wheels & Brakes
    Last Post: 15th January 2013, 23:04
  3. Rear upper control arm
    By arniedavo in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2010, 11:18
  4. Rear upper control arm
    By GSiFan in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 11:54
  5. rear upper control arms
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 24th October 2008, 18:29
vectra c rear upper control arm
how much does it cost to get rear arms changed on a vectra c
trailing arm vectra c 2005
vectra c rear upper control arm removal
opel vectra c upper control arm
vauxhall vectra upper suspension arm rear diagram
replacing vectra c rear upper control arms
how to change vectra c control arm
https:www.vectra-c.comforumshowthread.php94707-Rear-upper-control-arm
removing rear trailing arm vectra
2004 vectra rear suspension arms
vectra c rear banana arm removal
changing vectra c rear upper arms
