Results 1 to 10 of 24
Thread: Tyre Size.
    Regular Member padawun's Avatar
    Sevenoaks, KENT
    Default Tyre Size.
    I have a Vec.C 2.0t fitted with 215/50-17 tyres, I need to replace a couple of tyres before the MOT is done in December, I am told and Read in total Vauxhall this month that a common tweak is to fit 225/45-17 instead. (okay so long as they are fitted as a pair on the same axle).
    My chosen treads are the Vrededtein Sessanta, which are only available in 225/45.
    Has anyone done this mod, are there issues with wheel arch clearance or speedo calibration.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    If they are fitted on the front, then yes. The rolling radius will be smaller, thus the speedo and range will be out by a factor, but you will have no issues with clearance.
    Plymouth
    Quote Originally Posted by ghostrider View Post
    If they are fitted on the front, then yes. The rolling radius will be smaller, thus the speedo and range will be out by a factor.
    slower or faster??
    cambs
    Quote Originally Posted by padawun View Post
    hi m8
    no adjusting needed
    as the total hight of wheel and tyre stays the same as your old ones.
    225 is the mm width and 45 is the % of the width to the hight of the tyre.
    they will be fine m8
    On another planet
    Engine : 2.0
    I always thought that 45 was the 'thickness' of the tyre. i.e the height above then rim? - Hence the reduced rolling radius.
    Thats what the tyre dealer told me. He showed me a simulation on the computer and said that running 225 45 R17 would make my speedo run faster? Also that my MPG would suffer, using more fuel per revolution of the tyre. The effect is minimal, but there.
    cambs
    yes it is the thickness from the rim in % of the width.
    IT WILL STILL BE THE CORRECT HIGHT AND NO ADJUSTING OF THE SPEEDO IS NEEDED
    West
    changing from 215/50 to 225/45 does not make any difference to fuel cons or the spedo... i did this on my last Vec & when the tyres wear out on my current, i will be doing the same.
    hth
    cambs
    use this
    and put your old tyre size in an then do your new one
    http://www.etyres.co.uk/tyre-size-calculator.htm
    On another planet
    Engine : 2.0
    Well, there is slight difference. - 13mm diameter or - 2.01%.
    So i guess if you drove 40K a year, then you would notice it (fuel wise)
    But otherwise, as you say, no real change. As at 70mph, your speedo would only be 1.4mph out (high I think)
    Sevenoaks, KENT
    Thanks for the info guys, I found a tyre calculator on a different website,
    it lists the overall as 13mm or 2.01%. Given that the speedo is
    about 5% out at 90mph compared to my Road angel, I assume that would make it more accurate.
    235/45-17 are listed as 4mm or 0.62% different, but will they clear the arches.
    Another question, by changing the aspect ration on the tyres, am I in danger of putting abs faults in to the system.
  1. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  2. Tyre Size
    By ERIC in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2011, 10:45
  3. best tyre size for td pro 1.2
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2011, 15:32
  4. V6 Tyre Size
    By nellsey in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2010, 02:19
  5. Best tyre size?
    By arkhan78 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2009, 19:21
