Results 1 to 10 of 14
Thread: smokey on start up
    Regular Member PAULMAC77's Avatar
    warrington
    Default smokey on start up
    ive noticed my car can be a little smokey on start up now n then with a slight misfire but once its warmed up it seems fine. Any ideas what this could be?
    warrington
    no one have any ideas then..???
    Near Warrington
    is this with a warm r cold engine?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    i presume from your pic you have a cdti 150, then it sounds like the swirl valve rod has come off??
    warrington
    cold mostly, the rod still seems to be in place, i checked that..
    wolverhampton
    Smile
    you need to get your injector seal re done i need to have mine done the stealers told me a year ago that mine needed doing and i am having real trouble getting my car to start on these cold mornings
    warrington
    You mean the wiring mod? On injector 3??
    Regular Member jsr645's Avatar
    Northants
    I've asked this before and people just said its what diesels do! I disagree - I've had several diesels before and non have smoked on start up like this and I think there is something wrong...
    My 2008 150 CDTi does this and its getting worse as the weather gets colder. The smoke is white/grey and only does it on cold start. Anything after then it is fine. Also, its being a bit slow on cold start even after letting the glow plugs heat up.
    How do I check the swirl valve rod? I think it may be another trip to the stealers - what specifically should I tell them to check, cos last time they said it seemed ok and couldn't find the problem - maybe I can point them in the right direction??
    Sorry to Hijack Paulmac!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Sounds like the 3rd injector would be the most likely cause, the smoke is due to it starting (essentially) on 3 cylinders, pretty cheap and quick to fix.
    Northants
    I've heard before that a 2008 should have the new wiring from production, so shouldn't have this problem..
  1. Hesitation on acceleration and smokey start.
    By !tf in forum Engine & Drivetrain
    Last Post: 9th June 2011, 11:10
  2. Very smokey on start-up?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2010, 14:32
  3. Smokey Vec
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 15:57
  4. Help with smokey van please
    By sberrow in forum The 'Off Topic' room
    Last Post: 31st March 2009, 07:57
  5. Smokey Sri
    By MarkEllo220864 in forum Engine & Drivetrain
    Last Post: 27th March 2009, 11:56
