Results 1 to 10 of 11
Thread: warning light
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default warning light
    was reversing out of the drive this morning and the power steering failed and steering wheel light came on in the dash, turned engine off then restarted engine, light off and steering fine, should i be worried or just a glitch, was reading on here something about cim being slow to react, hopefully all will be fine, by the way is the power steering pump electric on the 2.0 dti 04
    Yes the power steering on the Vec c is the electro mechanical set up. On my 1.9 the pump and fluid container is mounted low down under the diesel filter housing behind the engine. If yours is not there it will be tucked away inside the drivers side front wing under the headlamp. You will probably have to remove the wheel arch liner if you need to check the fluid level.
    Jun 2009
    leeds
    Default power steering warning light
    Hi
    seems like a common problem. my 2.0 dti had the same problem the lights still on but it drives perfect. Yes your right it is electric but there is a a filler bottle sat on top of the pump. it is located behind the driver side headlight. very hard to get to. I took off the wheel and then the mudgaurd to get to it. Try topping up the fluid. Honestly ive been driving my car for nearly 2 months with the light on.
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    What fluid do you use?
    Bent, my name is Bent
    Mods: I polished it in september...
    I would normally use automatic transmission fluid to top up the power steering bottle.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    no dont use the red automatic transmission fluid get the correct stuff fella
    Apr 2009
    Bergen, Norway
    What is correct then?
    Are you VXR Enough
    13 Post(s)
    i know its green and got mine from vauxhalls
    Apr 2009
    Bergen, Norway
    Thanks for reply. Sounds like some special stuff then. Never seen green ATF-oil
    Are you VXR Enough
    13 Post(s)
    me either but its defo green stuff
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
