Thread: lambda sensor
    norn iron
    Default lambda sensor
    what would the long term effects be of driving with a faulty rear lambda sensor?
    my exhaust fell of the other night and bent my rear sensor my emmissions light is now on,
    the car is driving fine but just worried this may cause some sort of cat damage or is it just a matter of ignoring the light
    norn iron
    anybody got some good parts links?
    these sensors are a bit expensive so wont be changing it unless its completely necessary
    Melbourne, Australia
    The pre-cat O2 sensor is used to control the air/fuel mixture, so you need that to be working. The post-cat sensor is used to check that the converter is working properly - probably not so critical if a check engine light doesn't bother you.
    norn iron
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor again!
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:49
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
