Thread: Got blowers, but no heating!
    Oct 2009
    Bristol
    Default Got blowers, but no heating!
    Not technically minded at all, sadly! My blowers work, the air con works, but i can't get any heat out even on full. It has just come back from a full service as well. What is the likely fault, and is it easy to fix please.
    Regular Member SRimonkey's Avatar
    wednesfield
    airlock? i`d try this 1st
    Oct 2009
    Bristol
    Thanks for your reply. How would I solve an airlock, please..complete novice here!
    wednesfield
    pump the hoses coming out of the rad with the top off the coolant bottle and the engine running is how i got taught to do it,should move the airlock out,sorry its a short reply,can`t type well with arm in a plaster cast
    if not,then check this out
    http://www.vectra-c.com/forum/showthread.php?t=93247
    Oct 2009
    Bristol
    Urmmmm, Ok. I shall give it a go. Dare say I shall be back here asking more obvious questions as I go! Thanks for the advise, much appreciated.
    Sorry to read about the broken arm, didn't occur whilst trying to sort out an airlock out, did it ?!!
    Heres to a speedy recovery and it not being your beer holding/drinking arm.
    Oct 2009
    Bristol
    Sorry, when you say "pump the hoses", what do you mean?
    cheshire
    i think he means squeeze them with ya hands a good few times
    Regular Member wardy's Avatar
    Chichester
    another common fault is the electric motor that powers the air hot/cold mixer valve.
    I had this. It's located in the front passenger footwell, kind of behind the heater controls but further forwards. There should be a red lever visible connecting the motor to the mixing valve. If that doesn't move when the temp dial is rotated then thats the problem.
    As I say very common fault, check out the serch section
  1. Leaf Vac / Blowers
    By Leemarksmith in forum General Chat
    Last Post: 4th November 2012, 16:35
  2. blowers
    By bown in forum Introduce yourself.
    Last Post: 9th November 2010, 22:42
  3. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  4. my blowers
    By stuee in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 12:39
  5. No heating or blowers!
    By Butler in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2008, 21:01
