Thread: rear noise
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default rear noise
    my rear of the car makes a noise like the boot is left open well locked but not shut, only happens on speed humps anybody had this? it never use to do it but the past 2 weeks its started to do it, (the arb bushes are new) ive also noticed its never since i got the jack out of the boot and all that,
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    try driving with the parcel shelf removed
    Oct 2009
    Sandwell
    true, ill give that a try tomorrow,
    Oct 2007
    LINCS
    Make sure the rear seat is locked into place sometimes the catches unclip at the top of the seat on both sides.
    Oct 2009
    Sandwell
    Quote Originally Posted by pidge View Post
    i did have the seats unlocked about 2 weeks ago im sure i locked them back into place tho ill give it a check tho
    if not ill put some bubble rap down where the jack and spacer go, to see if that helps,
    Regular Member vxr68ni's Avatar
    northern ireland
    its the boot lock catch it needs adjusted
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by vxr68ni View Post
    That was my first thought too, need to do this to mine
    Regular Member old cruiser's Avatar
    slough
    If none of the above cures it mate, try some vaseline on the the V-groove of the catch in the hatch and where it meets on the boot itself, also on the rubber height adjusters, this cured mine amazingly enough!!
    Cheers Pete
    Oct 2009
    Sandwell
    yea but the boot shuts secure, can it still make the noise even when shut secure? and how do i adjust the catch?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah it shuts bu its no getting held tightly in place as it should, if you remove the black plastic cover where the catch is and slacken the catch bolts. Let the catch go down as far as possible and then re-tighten
  1. Noise from rear
    By stanlee in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2012, 13:07
  2. Noise from Rear
    By DesignforLife in forum Bodywork & Interior
    Last Post: 21st December 2009, 19:35
  3. rear noise
    By themurf in forum Introduce yourself.
    Last Post: 19th May 2009, 15:45
  4. Rear Noise
    By johnK in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:31
  5. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
