Thread: interior fan only works on the highest setting
    Regular Member howardc03's Avatar
    lincolnshire
    Default interior fan only works on the highest setting
    my interior heating fan only blows when it is on the highest setting (4) any other setting it does naff all. any one any idea if this is a easy fix or what it may be i.e is it common
    cheers all
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    common fault is the resistor quick release under glove box right under the dash
    lincolnshire
    diy fix or garage job???
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    should be able to diy i'd think as easy fit buy one then have a good look first but you sould be ok
    lincolnshire
    any guides on this fix anywhere matt?????
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    not that i know of on here sorry, just work at vx and have fitted 100's
    lincolnshire
    http://www.vectra-c.com/forum/showthread.php?p=1081017 found this bit of a guide on it
    cheers
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    cool good luck
    Sep 2009
    Swindon
    Fixed mine last week, problem was caused by the drain being blocked by the pollen filter must have been 5cm of water in there. In the guide is says not to solder the fuse back on the resistor pack, but I did should be ok if your quick.
    Only problem I have now is the noise the fan makes as it goes around, so will probably end up having to replace it at some point.
    Frenchman
    Regular Member suggs1971's Avatar
    east cleveland
    Yeah i had the resistor go on my veccy c, very easy to replace, took me about 15 mins. The motor was noisy on mine when i replaced the resistor, i removed the pollen filter and then sprayed some wd40 into the fan, there is a slight smell for a few days but does wear off and ive had no noise since.
  1. Interior light works, but not with doors open
    By Mark_k in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2012, 22:07
  2. Interior fan only works on 4???
    By craig-s in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2012, 21:05
  3. Highest Spec?
    By Gregg in forum Insignia Chat (READ ONLY)
    Last Post: 19th July 2010, 17:15
  4. Heater blower only works in highest setting
    By David Schofield in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2009, 19:59
  5. Highest Ever
    By moles-sri in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2009, 00:27
