Thread: Advice/Info Needed - Losing Water/Coolant
    Jul 2009
    The Rift, Cardiff
    Default Advice/Info Needed - Losing Water/Coolant
    As title suggests i've got a problem. Over the past week i've had the radiator light on the l/h dash screen, checked water, was down bout an inch. Topped up with water and antifreeze then next day light on and lost same amount. Its happened a few times now, cant see anything obviase or puddles under the car so have no clue where its leaking from.
    I have the 1.8 sxi. Any help or info on known problems or what to check and look out for would be appreciated.
    Cheers Bil
    WGAF#5
    possibly a hose or a leak on the top of the radiator core - only leaking
    when hot and escaping as vapor -
    best thing to do will be to wait until later when its a bit colder and run the car upto running temp open the bonnet and look for signs of steam escaping - will hopefully be fairly obvious as the exterior temp gets lower than the engine temp
    Jul 2009
    The Rift, Cardiff
    Thanks, i'll have a go tomorow. Hopefuly its something simple like a hose, someone sed it could be the headgasket, and I doubt thats cheap.
    Regular Member djr69uk's Avatar
    Midlands
    a garage can 'dip' your header tank and chemically test for HG problem. they don't charge a lot for this. another thing they can do is put dye in the tank that helps to trace if there is a leak somewhere.
    Check under the carpets.
    Jul 2009
    The Rift, Cardiff
    Thanks for the replys. I had a look today, during a short break in the rain, and could see some steam coming from the radiator (drivers side) but couldnt see if it was coming from the actual radiator or the vertical bit on the side.
    A friend said to use Radweld but i've heard its bad for the engine? Dose anyone know what sort of price a new rad is?
    Bil
    (glad its not the headgaset!)
  1. Vectra 3.2 Losing Coolant :(
    By HelloVauxhall in forum Engine & Drivetrain
    Last Post: 7th November 2012, 20:09
  2. Losing coolant but where??
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 12:27
  3. losing coolant
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 22:30
  4. Losing coolant
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:44
  5. Losing Coolant
    By parapaul in forum Engine & Drivetrain
    Last Post: 7th November 2008, 09:55
