Noticing this getting worse over the past couple of days. i,m getting a loud click or pop when i'm opening the drivers door. any ideas what i can do to stop it. thanks in advance guys.
sounds like the door strap (in between the two hinges) is cream crackered mate, not dear to replace, did mine a few weeks ago, removing the doorcard is simple enough, then 3 bolts and its done.
cheers mate. easy enough diy job then.
yep door car off (use the how 2 replace door speakers) and will take about half an hour - if its only just started check the bolts for tightness as they may just be loose rather than a worn check strap nylon wheel
Just done mine the other day, 16 pound retail or 13 ish trade
Door card off, remove speaker under bolts and 1 torx and replace. easy peasy and its very satsfying not to here that noise anymore!
cheers guys. i'm going away on wednesday so it'll have to wait till i get back. will let you know how i get on.
Hi Ballan I too need to replace my door thing too...
I hate how the clicking makes it sound like a banger!
yeah i know, i hate it.
Hi..mine were 'creaking' untill i sprayed grease out of a can onm all the joints and inside/along the parts i could see...voila!
mine use to be the same untill i got peed off then i got out the can of wd40 an sprayd my life away an then it got quieter an then just stoped makin the noise
