Thread: noisy door.
    Regular Member ballan22direct's Avatar
    isle of lewis
    Default noisy door.
    Noticing this getting worse over the past couple of days. i,m getting a loud click or pop when i'm opening the drivers door. any ideas what i can do to stop it. thanks in advance guys.
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    sounds like the door strap (in between the two hinges) is cream crackered mate, not dear to replace, did mine a few weeks ago, removing the doorcard is simple enough, then 3 bolts and its done.
    isle of lewis
    cheers mate. easy enough diy job then.
    WGAF#5
    yep door car off (use the how 2 replace door speakers) and will take about half an hour - if its only just started check the bolts for tightness as they may just be loose rather than a worn check strap nylon wheel
    Jun 2009
    durham
    Just done mine the other day, 16 pound retail or 13 ish trade
    Door card off, remove speaker under bolts and 1 torx and replace. easy peasy and its very satsfying not to here that noise anymore!
    isle of lewis
    cheers guys. i'm going away on wednesday so it'll have to wait till i get back. will let you know how i get on.
    Plymouth
    Hi Ballan I too need to replace my door thing too...
    I hate how the clicking makes it sound like a banger!
    isle of lewis
    yeah i know, i hate it.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Hi..mine were 'creaking' untill i sprayed grease out of a can onm all the joints and inside/along the parts i could see...voila!
    Regular Member Clugie's Avatar
    Jun 2009
    Liverpool
    mine use to be the same untill i got peed off then i got out the can of wd40 an sprayd my life away an then it got quieter an then just stoped makin the noise
  1. noisy cat
    By vectrabtcc in forum Engine & Drivetrain
    Last Post: 15th February 2012, 10:51
  2. Noisy Fan!
    By suresh.chohan in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 20:30
  3. noisy drivers door
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 09:26
  4. Noisy A/C
    By multi in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 20:03
  5. Noisy car help please
    By Higgins in forum Engine & Drivetrain
    Last Post: 28th February 2006, 22:27
