Results 1 to 10 of 15
Thread: Help needed CDTI 150
    Cambridgeshire
    Thumbs down Help needed CDTI 150
    Help please guys. Just started the motor this morning and there is a load ticking noise as if something is caught somewhere tapping/ticking. Popped the bonnet and it sounds like it's coming from the belts but not sure. It goes away when you use the throttle...
    If that wasn't bad enough my swirl bar is not connected and just lying on its side is that the end of it (do I need to fork out for the dreaded inlet manifold) or can I just pop it back on?
    Sep 2009
    Glasgow
    any lights on the dash
    Cambridgeshire
    Quote Originally Posted by nokiaman1978 View Post
    Not a thing mate. I haven't even noticed any 'limp' modes either. Don't have a clue how long the bar has been like that for?
    Edinburgh
    there's a couple of cheaper fixes on here, not sure how long they last. Otherwise, it's a trip to the dealers for a new inlet which ain't cheap. However, if you haven't noticed any difference since it fell off, why worry about it?
    darlo
    i have the ticking noise to have had it for abowt 6 month have had the belts and manifold changed in that time and still no better doest seem to have effected the perormance but its very anoying and the garage carnt seem to find out the problem
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    cdti's do sound like a bag of spanners on tickover, mine has always had the ticking/tapping on tickover, i hate it and would love to get rid of it, its the most crappy sounding engine on tickover ive ever had, everyone who hears it says it sounds s**t.
    Cambridgeshire
    Quote Originally Posted by Big Knox View Post
    So can I actually drive around with no swirl bar attached? If my inlet manifold is already beggared how can it make it any worse?
    Cambridgeshire
    I'm going to get a new inlet manifold and then get it fitted. Do I need to buy the actuator as well or will this still be working? (surely there would be lights on the dash if the actuator has failed?) Is there anything else that I will need to get to go with it? (I changed EGR recently)
    Cambridgeshire
    Anybody??
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    you wont get a warning light till the car works out somethings wrong could be days might be worth fitting a actuator and rod then its all done. just intake manifold gasket and throttle body gasket. timing belt needs removing as diesel pump needs to come of so if coming sup oon for replacement might be worth changing.
  1. Advice needed for my sri cdti 150
    By simmo3187 in forum Engine & Drivetrain
    Last Post: 3rd June 2011, 18:49
  2. Help Please needed on 1.9 cdti 150
    By Trist78 in forum Engine & Drivetrain
    Last Post: 19th January 2011, 21:46
