Results 1 to 10 of 23
Thread: code ncdc/cid
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Unhappy code ncdc/cid
    Hi Guys
    im in great need off help.
    Apparently my CID and NCDC are NOT unpaird from then original car that ive got it from
    Is there anyway to discover the code?
    if cant be done, ane compagnyes that can discover them, and/or reset the damm things so i dont have the "Display safe" every 5 seconds..
    (tech2 could program the items but NOT activate the "marry" with the car.)
    Northampton, UK
    When I recieved my CID from portugal, the VX tech told me it was still paired with the original system, but he was able to reset the software and pair it with my NCDC... I thought the NCDC wasnt paired with the car, just the screen?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Hi ken as long as they are a pair they will not need tech2 or unpairing from donor car,regardless if they are paired with a different code than your immobilizer.
    By the sounds of it they are not a matching pair i had display safe on mine when i bought a CID so it may be the screen is unpaired and the radio has a code in it still so the CID cant communicate with HU.
    If this is the case i know someone that can read codes from NCDC's but it maybe best emailing the guy you bought it from.
    Irmscher Insignia CDTI 130
    Engine : 2.2 Direct
    we couldnt reset it.. even (atleast we couldnt see the option to do so) but we could change all the bits in it.. the same with the ncdc..
    It just simple wont accept the code for my car..
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Did you buy it as unpaired or paired ? have you a link to the item you bought ?
    And Nick your correct they are coded to each other not the car
    Engine : 2.2 Direct
    well emailing the guy... well then i have to wait like atleast 1 month until reply
    what of the bits thats still locked is a good question.. as it wouldt accept the code for either the screen or the ncdc..
    we had a fail the first time.. (as ive put the pin in the diagport wrong the first time) but when corrected.. still a no go.
    Engine : 2.2 Direct
    should be unpaird.. was listed as that.. its more than 3 months ago so not sure it i still can find it. (ill try)
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds as if ones still coded i thought you bought them from someone off here and they told you they were matching ?
    Northampton, UK
    So I assume they couldnt have come from the same car and are paired with different units? I bet he's bought them to do the same mod as you and found out he couldnt get it to work.
    Engine : 2.2 Direct
    nope not on ebay anymore..
  1. Radio NCDC xxxx code ?
    By tomhrb in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 21:29
  2. ncdc sat nav disc
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 23:01
vectra nCDC coding
