Thread: No heater a/c heated rear window
    edmonton
    Default No heater a/c heated rear window
    The entire heating, a/c, heated rear window , fan is not working.
    Have checked fuses and they appear ok.
    Car is vectra c life estate 07.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    i'd start by trying to borrow a heater control pannel only quick release
    edmonton
    (i'd start by trying to borrow a heater control pannel only quick release)
    Not sure what this is Matt. Do you advise the unit be removed and checked. I believe there are 2 fuses that control this unit, there is no power to the unit at all.Can something be reset?
    I had a similar problem a while ago with the all the gauges, and I managed to reset something by removing one of the fuses.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    borrow the heater pannel with the 3 dials and 4 buttons. remove your and plug it in if the fuses are fine see if it works
    edmonton
    how is the panel removed? can you advise please.
    Oct 2007
    Shropshire
    It just pulls out. If you remove the radio first its very easy...
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Remove bottom coin tray put fingers in from behind and push out
    Irmscher Insignia CDTI 130
    edmonton
    thanks for that, have pulled unit out, quite easy!
  1. Replies: 6
    Last Post: 15th May 2013, 18:55
  2. Heated rear window
    By Guss in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2011, 13:28
  3. Heated Rear Window
    By si_hoss in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2009, 15:03
  4. Rear heated window
    By BigP in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 20:15
vectra c which number fuse is for heated rear window
