Thread: Pulling to the left
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default Pulling to the left
    My car has started pulling to the left, ever since I went to get my wheel alignment checked and he f***** it up, "one of his gauges wasn't in properly" or something another. I've been to a four wheel laser alignment since, and it's not fixed the problem whatsoever. Recently went through an MOT, and it said "steering wheel has slight play" could this be the problem? People recommended a pinch bolt to fix this problem, but wasn't 100% sure what I was looking for!
    WGAF#5
    when does the car pull to the left??
    try driving on a straight flat piece of road and when safe to do so
    take your hands off the steering wheel and see if it pulls to the left then
    it could be the camber of the road and now that your wheel alignment has been completed and is correct - you may notice it more ??
    with regards to the play in the steering - i would take it back to the mot testing station and ask them to clarify the diagnosis as when the testers used to manually write the advisories down they could be precise - now they have a selection of options that they can pick so its slightly more hit and miss - at least if they tell you the exact area where the problem lies you can get it sorted corretly - rather than tweaking the pinch bolt on the rack when the free play could be on a track rod arm
    regards
    Dez
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    where the colum uj meets the rack under the bonnet their is a 13mm pinch bolt that works its way loose and gets crud in it. take the bolt out clean the shaft and uj then refit the bolt tight
    Sep 2009
    Warrington
    regards
    Dez
    I notice it on roads with a straight grade/without a camber, I let go of the steering wheel and it pulls left, or when I align the steering wheel central, it also pulls left! He's mates with my dad the MOT fella, so i'll get him to ring up and see exactly what the problem was!
    Quote Originally Posted by mattv6diesel View Post
    People say it's inside the car, some say it's under the bonnet but yeah I think i'm gonna take it to the MOT place first like Dez said, before I start messing with the pinch bolt. Thanks for the advice anyway guys!
    It's rare to find a road without camber, even what looks like level and flat often isn't
    I have managed to find one such road several miles away
    The sign this is completely level is when it rains, as even with light rain it becomes like swimming pool!
    Most UK cars will feel like they are pulling or driving to the left
    You can recheck this by driving in the "wrong" lane, and if the car still pulls the left then you know the toe setting is incorrect
    Quite often it can take two or more trips
    Be specific when you get front wheel alignment done
    Watch that the steering wheel is completely level when they fit the clasp
    Equally, the engine should be running throughout (as the Vectra has power steering)
    Oct 2007
    Shropshire
    My car is very camber sensitive after fitting 18" wheels. I have stretched extra load (thicker side wall) tyres on which have virtually no give in them, and now mine pulls to the left, but if you drive on the opposite side of the road (when its safe to do so!!!!) it will pull to the right. It is also very affected by the white lines!
    As far as I know this can be a common problem when fiting big wheels with lower profile tyres...
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    4 wheel laser alignment isn't the same as a full geoemetry set up. Some bed time reading http://www.wheels-inmotion.co.uk/tec...ignsystems.php. Might also be of interest to others with a pulling issue.
    A full global set up "might" cure your pulling.
    Sep 2009
    Warrington
    Quote Originally Posted by gtr1000 View Post
    My dad recommended a full geometry check, what sorta money am I looking to spend on one of those?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Danialj32 View Post
    Approx £60-80.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    In my experience, knowing the basics of global geoemetry is a must BEFORE you take it to a place that claims they can do it. There are many, many garages that have the necessary equipemnt (Hunter or equivalent), to do the work but what most lack is the expertise and knowledge. There are people like Tony Bones at Wheels in Motion scattered around the county but you need to find them, usually by customer recommendation. A good rule of thumb is to find garages that set up track day cars, specials or exotica. Oh, and be prepared to travel to find a good un.
    So, do your homework, ask the right questions, understand what you want from the garage and what your expectations are. Forearmed is forewarned.
  1. Pulling to the left.
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2012, 00:23
  2. Pulling to the right, then left.. Help!
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 18:06
  3. Pulling to Left
    By Diet1985 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2009, 20:39
  4. pulling to the left
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2009, 19:51
  5. Car pulling to left
    By andy1103 in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2009, 22:52
