Results 1 to 3 of 3
Thread: 3.2 V6 TC and Power Steering Cut Out???
    Oct 2009
    Kent
    Default 3.2 V6 TC and Power Steering Cut Out???
    Can anyone help or has anyone experienced the same problem,
    For some reason when ever you push the car a little hard (when the TC comes into play for a little bit) the Traction control system turns it self off (warning light comes up) and the Power steering cuts out (warning light and heavy steering) as soon as you turn the engine off then on again they clear and it is ok.
    It is also loses about an inch of water from the engine coolant about every 3 - 4 weeks but i have had it checked over and it isnt the head gasket but unable to pin point the actual problem - maybe related.
    Any info welcomed,
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Manual or auto?
    I suspect they are unrelated
    The first sounds like CIM module failure
    When this happens, try the indicators and see if they cancel correctly
    The second sounds like either early signs of head gasket failed, when you switch the engine off listen for gurgling, or hard seal failure, check for coolant leaks under the car after it has cooled down after about 3 or 4 hours (more common on engine cooling on cold nights)
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
