View Poll Results: Have you had AFL & Headlight washers installed after retro fitting your HID kit?
Voters
14. You may not vote on this poll
  • Yes, I have AFL & Washers
    0 0%
  • No I don't have them installed.
    14 100.00%
Results 1 to 10 of 19
Thread: Retro fitting AFL & Washers after HID kit installation.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default Retro fitting AFL & Washers after HID kit installation.
    Any idea how much it'll cost to do this?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    u dont need them.
    Sep 2009
    Warrington
    Quote Originally Posted by bobby-tupper View Post
    u dont need them.
    Just read your post then mate! Still interesting to see who has done this!
    Headlight washers are fairly simple, there's a how2 guide for it. Even if you make it simpler by just tapping into the winscreen wash pipework...
    AFL would require new headlights, sensors and christ knows what else... Having AFL in my current car, I'd say it wasn't worth the hassle to be honest, it's a fancy gizmo that doesn't really accomplish much...
    WGAF#5
    theres a thread on here about a plug in adaptor that will give you afl via the front gof lamps - similar to the mercedes system
    the unit plugs in via the obds but is about 100quid it also gives you a few other tpys as well
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    and thats the www.happylightshow.de
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    washer kit is about £100.00 + tech 2 to get it to work.....
    you need,
    bigger washer bottle,
    pipe,
    jet's,
    jet housing's, (+ painting)
    all high pressure joint's,
    high pressure pump,
    and all the clip's etc..
    hth
    Midlands Mod Shop - NFFC.
    Sep 2009
    Warrington
    I think the cheaper option would be just getting my headlights checked
    I never got round to activating mine via Tech2 on my old car, but having the headlamp washers there (even if nothing came out of them...) probably made it look less suspicious with the HID kit than if they weren't there...
    Sep 2009
    Warrington
    Quote Originally Posted by Penfold101 View Post
    Deception
  1. What a day retro fitting
    By marc vectra sri in forum Styling
    Last Post: 31st July 2012, 22:11
  2. retro fitting headlight washers
    By taffy bhoy in forum Styling
    Last Post: 21st September 2011, 14:10
  3. Retro fit Face-Lift Headlight Washers
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 13:35
  4. Retro Fitting Headlamp Washers
    By PedroMV6 in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2010, 20:16
  5. retro fitting afl
    By andy.l in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 14:42
instaling afl headlights vectra
